Hot Rods A new project - 1941 Ford Shop Truck
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Oct 11, 2016.
  1. the-rodster
    the-rodster
    Subframe fully welded, flipped upside down, ready to start assembly.
    The 39 guy and kidcampbell71 like this.
  2. oldsman41
    oldsman41
    Shop truck, hell I’d be happy to make it my daily.
  3. joel
    joel
    Are you going to rivit the sides to the subframe or weld?
  4. the-rodster
    the-rodster
    The current plan is 1/4 inch carriage bolts.
    Rich
  5. cederholm
    cederholm
    Love this! Beautiful job.
  6. the-rodster
    the-rodster
    The bed is coming along nicely.
    I had doubts that the original bedsides would look OK, I think they do.
  7. Bandit Billy
    Bandit Billy
    That is a lot of hardware! Thanks for posting the pictures of the bed assembly.
  8. joel
    joel
    I think the bed is coming along very well. The bed sides look good. Keep at it.
  9. the-rodster
    the-rodster
  10. greaseSlinger57
    greaseSlinger57
    Does anyone know if these 1940 Ford pickup will bolt on the side of a 46’ pickup bed? How close are the dimensions does anyone know? I can’t seem to find a 42 - 46 left bedside fender!
  11. greaseSlinger57
    greaseSlinger57
    That truck is going to be sweet, too!!! Keep it up!!
  12. treb11
    treb11
    The 38-41 beds are 46" wide, 42-47 beds are 49". The big side panels are the same. The differences are in the subframe crossmembers, the header panel and the tailgate. I could only find a later bed for my project, so it will be rebuilt to earlier configuration. And NO you cant have my fenders! BUT, 42-47 fenders are different than 40-41 where the running board attaches.
    Post your location info so folks can work with you to find your fenders.
    Jake.forbis and Hamtown Al like this.
  13. Bandit Billy
    Bandit Billy
    Did you mean to ask if a 40 "fender" will bolt on your 46 truck? If so, they will but need a bit of work. The fender is slightly different where it attaches to the running board, here is the patch. EMS sells them.
    Jake.forbis likes this.
  14. greaseSlinger57
    greaseSlinger57
    Yeah I did mean to write that. Wow! Okay, that is awesome you guys, thanks!! I couldn’t find that info! I’ll update my profile as well.
  15. the-rodster
    the-rodster
    Bed on, not bolted yet.
    From the looks of it, the back is gunna need to come down and inch or two.
  16. the-rodster
    the-rodster
    Front fenders, barely bolted on.
  17. joel
    joel
    Looking good. I’ll send a pic of mine. 20 1/2 inches from the bottom of the bed side the floor. IMG_1086.JPG
    8.20-15 on the back, 5.60-15 front.
  18. joel
    joel
    Fordor Ron and mcsfabrication like this.
  19. the-rodster
    the-rodster
    Dang! Mine is at 25 inches.
    Rich
  20. B.A.KING
    B.A.KING
    Are those new springs? if so they will settle quite a bit.
  21. joel
    joel
    I'm planning a reversed eye rear spring with sliders, which could raise the rear 1/2 to 1 in. I only have 4 or 5 leafs in my present spring and if I add sliders between the leafs it will settle probably an inch. It doesn't move much now because of rust and wear.
    I agree with B.A.KING on the springs settling at least an inch.
  22. the-rodster
    the-rodster
    Yes, new parallel leaf springs, that have been under the truck for almost a year, but without any weight, really.
    There are currently no lowering block, looks like I may need some.
    Rich
  23. speed v8
    speed v8
    Just read the whole thread, awesome work! The engine sounds great btw!
  24. Racerex
    Racerex
    I used a Chassis Engineering parallel leaf kit in my 39 pickup with new springs. The instructions of the kit said that the springs would settle about an inch after 500 miles of driving. I had to put 2-1/2" lowering blocks on mine in order to get the back of the truck to sit right. If you're thinking about lowering blocks, I made mine out of rectangular stainless tubing and it was really easy. Now the rear tires (7.00-16s) are slightly tucked in the fenders.
  25. the-rodster
    the-rodster
    I used a WEEDETR parallel kit in mine, mostly because they claimed you wouldn't need lowering blocks. I'll know more when the fenders are on, but I'm thinking two inch blocks may be in order.
    Rich
  26. the-rodster
    the-rodster
    I installed the rear fenders, did some measuring, then installed two inch blocks.
    It looks about right....
    jazz1, low budget, Hotrodmyk and 3 others like this.
  27. The 39 guy
    The 39 guy
    Yes , looks like a real nice stance!
  28. joel
    joel
    I agree, it fits the fender just right.
  29. Los_Control
    Los_Control
    from TX
    I love it .... that girlfriend of yours, does she have a sister?
  30. the-rodster
    the-rodster
    She won't say :)
    Rich
