Technical Headlight Placement
Discussion in 'Traditional Hot Rods' started by dmdeaton, Nov 8, 2018.
  1. 34Larry
    34Larry
    Sent you a PM on my placement.
  2. mcsfabrication
    mcsfabrication
    Like to see the King Bees.
  3. dmdeaton
    dmdeaton
    Here you go, option Bee. ;)
    I would black out the bar.
  4. dmdeaton
    dmdeaton
    I would like a set of BLC's or something with the park lite on top as I already planned and ran turn signal wires with the headlite harness. Not a game stopper though.
    Can you get seal beam LED replacement? I am trying to keep the current draw down some. Green, you know!
  5. Blues4U
    Blues4U
    from So Cal
    Those King Bees look far better. No comparison IMO. King Bees for sure!
  6. dmdeaton
    dmdeaton
    Wow, looking at that front view pic. Check out the radiator not lined up with the body! :eek:
    Stogy likes this.
  7. rustythumb
    rustythumb
    stock headlights would be correct for a pre-war hot rod, yes?
  8. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>Wow, looking at that front view pic. Check out the radiator not lined up with the body! :eek:>>>
    Nah. Just an optical illusion. It's actually the frame that doesn't line up with the body. 8^) Jack E/NJ.
  9. 32Stoker
    32Stoker
    My $.02...Bees and Dietz look wrong on your build. Too much of a 50’s/60’s era statement. I vote BLC’s with turn signals at the height you’ve got and front edge about 1-2” forward of the grille shell. Cool car!
  10. Bandit Billy
    Bandit Billy
    Mine is a 34 so a bit off the beaten track. They are 34 passenger lights tucked back to the grille and per my avatar, just peaking above the tire tops. I tried a lot of positions, this was my favorite. The tires move peg to peg well outside the lights.
  11. Blue One
    Blue One
    from Alberta
    Here’s where I put mine.
    4E683B61-6776-4C72-804E-6E297F20D670.jpeg EBD47540-D8CA-454E-B2EB-8C0DF3B06711.jpeg
  12. I would go back a hair
  13. dmdeaton
    dmdeaton
    just threw this together for looks. I am going to source a set of originals with patina, these will do for now. Don't know about the bar. I have separate stands and will play around with moving them back. thanks guys, love all the tips.
