Looking for idea's on DIY adjustable exhaust stands. Working under a hoist and would like to steal someone's idea's on how to build a simple adjustable exhaust pipe, muffler, stand. Thanks!
One of the hardest parts to make for the average home shop is the threaded portion for fine tuning heighth once the stand is "in place", now, if you're standing there scratching your head and need it NOW you probably don't need to read any further. Stop at any garage sale and you no doubt will find a set of exercise dumbells or barbells. Cheap too, look for the style that has the big acme thread on the ends, these male/female shafts/nuts can be welded onto the stand of your design (the easy part). Granted, they are more heavy duty than exhaust components would need but they can be used for other automotive projects. Light duty versions can be made the same way by using the parts off those small aluminum travel trailer support stands. I see them regularly at garage sales too. Like these here: https://www.homedepot.com/p/Camco-Olympian-Aluminum-Jack-Stand-2-per-Box-44561/205518965
Maybe dry-wall ceiling stands? Quick to put, quick to remove, not expensive... Something like that. If i have them available in Europe, in US they for sure are too. Only requirement is to change upper part to round one to better keep tubing in place.
Mufflers shops around use a disc from a disc harrow, weld a section of exhaust tubing to it , then put the next size smaller tubing inside it, weld a nut to the outside tubing, put a l shaped bolt in it, weld the bottom of a muffler clamp to the smaller tubing and you’ve got it. I have also seen some of the guys get fancy and add an Acme threads and nut to the top for fine adjustments. Bones
Mr. Kozlowski idea gave me one, looking into a telescoping light bulb changer for high ceilings and modify. Bone's idea would be more traditional........................
These aren't that expensive....a little more if you get the foot peddle lift. Heavy enough for holding rear axle when you need that also https://www.amazon.com/STKUSA-Under...74659&sr=8-10&keywords=under+hoist+jack+stand
There are dozens of way you could go on that using the unit upspirate suggested as a pattern. A piece of tubing welded to a disk, wheel or piece of steel plate to hold it upright with a piece of allthread in the end with the piece to hold the pipe. The only thing I can think of is that they shouldn't be too heavy weight wise or too top heavy. You don't want the falling over when you don't have a load on them.
I've always seen the tube within a tube, with a nut welded to the side and a bolt with a rod welded too it (T handle). A piece angle iron welded across the top in a "V" position and it all welded to an old wheel or brake drum. Drag over, extend into position and twist the T bolt to lock.......then start welding. I plan on building a few when I have a lift in the future.
^^^^^^^^^^^^ You pretty much need a nut and screw for fine tuning instead of pre drilled holes 3" apart^^^^^^^^^^^^
I've seen my exhaust guy use ratchet straps and those big solid chunks of styrofoam before. Sometimes his bays are full. The rookies use the exhaust screws .... while the master uses what he has. The styrofoam is chunked between the straps and pipes. I imagine a second hand is used to balance pipe and hang strap. Hell .... finding an extra hand is easier and cheaper than the alternatives ... though. Yes ?
Both NAPA and HF sell adjustable stands about 7 feet tall. You can take them down to about 4 feet. The HF ones are of higher quality and very sturdy.
My stands are spring loaded, they work like caulking gun. They are very light, but can support some weight. And they are readily available. Other stands mentioned are quite heavy compared to this. On the other hand, in garage i have also trans jack to use when i need something heavy duty.
OK ,OK, OK , I didn't paint the stand, But believe me, welding a nut on the side won't cut it for long term, the bolt with a wing on it, eventually bends the inner pipe so outta shape it doesn't slide up and down easily.. This piece has served me well, since 1967. ( when I need them, have 4 )
