Technical Headlight Placement
Discussion in 'Traditional Hot Rods' started by dmdeaton, Nov 8, 2018.
  1. dmdeaton
    dmdeaton
    I have looked at lots of pics on here and need a little push before I drill holes. Am I close on where these should sit? I still need to bend my upper shock mounts and make sure they don't interfere.
  2. dmdeaton
    dmdeaton
    I still need to heat and straighten the left horn. That's next on the list. Wires are loomed through the grommets just to get them out of the way until mounted.
  3. F&J
    F&J
    No replies in hours..
    Best idea?>>Do what looks good to you. If you are asking what was once done ?...those low placements and being stock lights are not what was used on postwar builds. That style you have is Y2K, or following the trends.
    Mount both of them and work on something else.... after a while you will either like it or change it. Roll it outside for a few hours if you can, look at it from a distance & different view angles, that will tell.
    Jet96, RMR&C and tb33anda3rd like this.
  4. fourspd2quad
    fourspd2quad
    Yeah that is a personal taste thing. Put them both on and spend time looking at it. If it looks good to you then it's right.
  5. junk yard kid
    junk yard kid
    D-Russ, da34guy and Nicholas Coe like this.
  6. Mr48chev
    I have to agree with fourspeed2quad there. The stand back and look or even sit back an look for while to see if that is exactly how you want it and your aren't settling for how it looks just because you are tired of fooling with it. Damn that's perfect beats the hell out Yea, that will pass.
  7. fiftyv8
    fiftyv8
    from CO & WA
    Set both up first before standing back so you can take in the full picture.
    They need to look right as a pair.
    I'm pretty sure that is what the Bishop said to the Barmaid right....
    Jet96, VANDENPLAS and F&J like this.
  8. dmdeaton
    dmdeaton
    This is what I was looking for, to get a idea where to start. Do I need to source some BLC"s? I don't like the big stock lights either. What type of mounting would you use on a post war to get them higher?
    I have a set of old King Bees laying around.
  9. dmdeaton
    dmdeaton
    Again, what I am looking for. This stuff is new to me. I am not trying to make a exact replica, but I do want the post war kinda look.
    thanks so far for the comments.
    rjones35 likes this.
  10. Petejoe
    Petejoe
    from Zoar, Ohio
    This was on a fendered ford but it a lot of ideas were presented.
    I agree, don’t get into any fired up hurry placing them or even changing them.
    By the looks of your build you have plenty of time to make this minor decision.
    https://www.jalopyjournal.com/forum/threads/lets-critique-headlights-on-the-34.1045058/
  11. sloppy jalopies
    sloppy jalopies
    my vote is to align the bucket / bezel seam with the front edge of the grill...
    bymanr likes this.
  12. rusty rocket
    rusty rocket
    I,m with everyone else move them back. This is my Pops roadster, we set his lights up just a bit in front of the radiator shell. IMG_0928_2.JPG
    RICH B, bymanr and dana barlow like this.
  13. oldsman41
    oldsman41
    I like them set back a bit rusty rocket nailed it in my opinion, but its your decision.
  14. wuga
    wuga
    Flush with the rad.
    Warren
  15. Ralph Moore
    Ralph Moore
    IMO look too far forward, but as said, YOU have to like them. Have you checked with tires on, turn lock to lock for clearance?
    Another example for you;[​IMG]
    dana barlow likes this.
  16. Dirk35
    Dirk35
    I agree with the others. You need to fix that driver side frame, then put your shock mount brackets on. Their presence will fill some of the visual void. Then try to move them back about an inch. Personally, I think they'd look correct with only about an inch -to- 1 1/2 inch of the headlight sticking forward of the grill shell.
    Nicholas Coe likes this.
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    Headlight seam aligned w/the front grill edge is a good starting point.
    rjones35 and bymanr like this.
  18. That's like asking the Bar Tender if you should go talk to the Blond or the Red Head. When he says the Red Head your reply is "but the Blond has nicer Boobs" instead of Thanks.
    The Wizzard
    Jet96 likes this.
  19. jailhousebob
    jailhousebob
    from Illinois
    I like them back and close to the shell.Alot depends on the size of the headlights. These are the 682-c lights on my coupe. they are a large light .I would maybe prefer they were a bit further back but i would have had to bring them out toward the wheels to clear the grill shell and that didn't look good to my eye.Like others have said,spend alot of time moving them around and looking from every angle and with different lights if you have others available .Maybe you have some hot rod friends with some spare lights that you can borrow for comparison.I set mine up with a set of 903-j's at first,which are a smaller light. It really changed the look but i eventually settled on the 682's but it took a while to decide.I personally am not a fan of model A or 32 lights but in some cases they look great.The pic posted by Rusty Rocket of his dads roadster is a perfect example. To me it doesn't get any better.bob
  20. dana barlow
    dana barlow
    from Miami Fla.
    1. Y-blocks
    For best of all worlds, if top of headlight is at or above front tire top,they work well,lower then that not so well an looks like poor engineering to those that know. How far forword is about what you like. With flathead motor you can use the big old type lights,it fits OK with style,but we mostly replaced the big old ones,do too them being bad at lighting the road after 7in. sealbeams came out=good light an looked racyer/more hotrod.
    F&J and Pist-n-Broke like this.
  21. sloppy jalopies
    sloppy jalopies
    Older fellow told me that they used to mount their lights on the fender braces with the fenders and upper half of the brace removed, as the local constable didn't seem to notice it was a rod, like he did the lowered lights...
    hotrod geezer's history... be a good book !
    hotrodarchaeologist likes this.
  22. Ralph Moore
    Ralph Moore
    Bandit Billy likes this.
  23. dirty old man
    dirty old man
    Headlight size and placement are very much a matter of personal preference, but since you asked, I'll share my opinion(s).
    At 5 days short of 81, I'm older than most any of you, and lived the age yall are try to emulate:):cool:. As Dana said, one of the first things to go were those big old headlights and 7" sealed beams replaced them, something like the Dietz and King Bee lights Speedway sells now. The resilvered reflectors and high power halogen bulbs of today weren't available and you couldn't see shit with those old lights:confused::eek:
    As for placement I, like Dana like fenderless cars to just have about a third to a half of the diameter of the lens above the front tire, and the lens to be centered on the grill shell if it's an "A" or '32 grill shell.A '33/'34 is sort of the same.
  24. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>need a little push before I drill holes>>>
    You already got a hole there. Use it with a piece of angle iron or whatever to mount the base on. If you don't like it. Then use another arrangement using the same hole. Jack E/NJ
  25. Kinda traditional placement; Guide 903 lights on hot rod headlight stands. Not too big, not to small, not too low, or oversize either. Arrow 775 lights would be another medium size choice, too.
    Nicholas Coe and F&J like this.
  26. 51 mercules
    51 mercules
    My BLC's are forward.[​IMG][​IMG]
    Stogy and F&J like this.
  27. F&J
    F&J
    ^^ Those 904 "percolator" lights were the final part I found for the build. That really made my day at the Milltown, Mass swap where apparently nobody wanted them..
  28. Jack E/NJ
    Jack E/NJ
    from NJ
    And looks like they'd bolt right up to the hole that's already there too. Jack E/NJ
  29. thirtytwo
    thirtytwo
    Post war 95% would have sealed beams...
    don Montgomery books are an excellent source of pre and post war pics of hotrods 100s of pics of things like headlight placement, stance shocks ect
  30. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>I do want the post war kinda look>>>
    Here you go. Correct headlight placement ca. July 23 1947 Jack E/NJ
    Habitual traffic violator
    Stogy, Jet96 and mad mikey like this.
