Customs 8BA Main Seals
Discussion in 'The Hokey Ass Message Board' started by welshy1, Nov 5, 2018.
  1. welshy1
    welshy1
    Hi members ,
    I posted my problems with my ford side valve v8 , being very tight to start from a full rebuild , ,was not happy when it grabbed after 2 hours running , so I stripped it down again , and found the rear main bearing was stuffed.
    I went to see a friend who has had a bit to do with this 8ba motor, and said to me ,
    " IF THE REAR MAIN SEAL WAS VERY TIGHT, IT HEATS UP THE BACK END OF THE MAIN BEARING ,TO THE POINT THAT IT GETS HOT ,EXPANDS, and that is why it locked for a second then freed it self up again. "
    Any members heard of this happening ?
    I would like to know for my own experience please.
    ANY HELP WOULD BE GREAT.
    Many thanks ,
    welshy1
  2. 5window
    5window
    I don't have an answer to your need, but you will get many more appropriate responses if you re-title this thread so that the problem is identified. Something like-"8ba Main seal issues".
  3. Mike51Merc
    Mike51Merc
    I don't believe that a tight seal can cook a bearing.
    Sounds like your bearing clearance was too tight.
    Bandit Billy and 57 Fargo like this.
  4. khead47
    khead47
    What Mike ^^^^^^^^ said X2
  5. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
  6. welshy1
    welshy1
    mate thats what i thought took the crank back to the shop and he tested it again and said it was rigjt on for the 20th main said the rear seal is what done it.just does not fit with me i must admit it was tight to turn over JUST THE CRANK so what is wrong .the front and middle were ok i am lost NEED HELP GUYS BEFORE I ORDER A NEW SET OF MAINS crank run ok in the block before i had a differant crank ground asked him to check to see if it happened to be bent? surely not .cheets .welshy1
  7. Terrible80
    Terrible80
    You could try turning it w/o pistons. Untorqued, then tighten one cap at a time. Maybe see where or why it binds.
    Sent from my LG-TP450 using The H.A.M.B. mobile app
  8. joee
    joee
    someone doesn't know what they're doing. I would find someone that does
  9. Does the block have the correct main caps on it?
