Technical ***November 2018 Banger Meet - Weather Changing***
Discussion in 'Traditional Hot Rods' started by Jiminy, Oct 31, 2018.
  1. Jiminy
    Jiminy
    Coming Events: (PM Jiminy with additions/corrections)
    November 4th, So. Cal. Hill Climb
    November 10th - 11th, El Mirage
    2019 International Speedsters Trials & Reunion June 19th-22nd, 2019
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $31.00 for color, $24.00 for B/W (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    russell7088 likes this.
  2. blgitn
    blgitn
    Checking in.
  3. denis4x4
    denis4x4
    from Colorado
    Finishing a brake job and installing tube shocks B154593A-199E-46A2-995D-591A930BDCD9.jpeg
    stillrunners, Dannerr, Deuces and 2 others like this.
  4. Crazydaddyo
    Crazydaddyo
    No news is no news.
  5. what about fake news............
    stillrunners likes this.
  6. noboD
    noboD
    It doesn't exist or it wouldn't be fake.
  7. Kiwi 4d
    Kiwi 4d
    60D0C3E6-FF41-45B3-8D21-55B04309EB62.jpeg F750AAEA-932B-4CAA-859C-5E8E3B018331.jpeg Swapped in a 35/36 rear with 3.54 gears into the banger 32 today. Relatively straight forward , used 35/36 radius rods shortened about 15” . Used a 35/36 spring with scallops ground at spring perch points to mimic the 32 spring curve with teflon lined spring pack , as these were already in the spring. Juice brakes all fitted OK. Park brake worked great also.
    The original 32 rear had dodgy welded spring hangers , probably from some one cutting them off to fit in a lathe as it had new bearing races on the axle ends. They looked like an accident waiting to happen.
    Think I will need a 17 or 18 count speedo turtle .
    The rear sits approx 1” lower , but the axle moved only 1/4” forward , but visually looks more unfortunately. Though the spring rate feels great and still 4”of travel so able to carry a decent load.
    Nothing is painted fancy as this is how the 32 looks ,used and fun ,ready to haul.
    tinsled, cactus1, Dannerr and 6 others like this.
  8. drtrcrV-8
    drtrcrV-8
    Good tip for an easy way to get 3.54 rear gears!
  9. V4F
    V4F
    from middle ca.
    nice truck
  10. JT1930
    JT1930
    953CA5EC-D146-45B9-AE11-11019EFA4884.jpeg Don’t know if anyone has ran into this problem but good to know and check. Sorry for the novel post.
    My banger has the FSI distributor and plug wires they make. After putting the dual updraft carb setup on the car was sputtering and running like crap full throttle. (Idle and blipping the throttle was fine) So thinking it was a fuel issue being too rich since plugs were sooted up I began to play with jet sizes. Still same symptoms. As I pulled the first plug wire I noticed it was turning. The plug wire ends are a screw in type of connector. All were loose but cylinder 1 and 2 were the worst. Recut all wires and put a dab of red loc-tite on screw ends. Just something to check in case you’re at a loss or get a brand new wire set from them. Other than that I love this ignition.
    Also hello from Rhode Island......
    cactus1, Dannerr, Deuces and 4 others like this.
  11. V4F
    V4F
    from middle ca.
    I use wire wires from racing ap . no troubles here
    JT1930 likes this.
  12. Binger
    Binger
    from wyoming
    Checking in from Cheyoming!
  13. winduptoy
    winduptoy
    Kiwi 4d is going to build an OHV Banger, Cragar/Miller head engine. IMG_20170325_172737085.jpg
    This is for him....well and anyone else who cares....because this photo didn't make it on the thread he started and I replied to...
    The spring cap had interference with the rocker or the rocker with the cap...they collided in the closed position.
    Used offset keepers to lower the cap, it also helped with closing pressure on the springs. I recall the shim between the rocker stand and the head was in the neighborhood of .032" to help with the contact placement of the rocker on the valve stem. Got to remember to put a hole in the shim that corresponds with the oil passage to the rocker shaft.
    That's my check in for the month.
    Larry
    chriseakin, Dannerr, Deuces and 6 others like this.
  14. Johnny Nitro
    Johnny Nitro
    from Chicago
    Back with another question:
    Is anyone running the new Edelbrock 94? What jets, and pv are you running? I seem to be running rich. Also, is there a way to determine what pv you need I you don’t have access to manifold vacuum?
  15. winduptoy
    winduptoy
    No direct experience with the repop 94. On my original, B cam, A engine, Lion head. I have adjustable main jets. I'm running a 4.5 power valve.
    Good luck
    Sent from my XT1254 using The H.A.M.B. mobile app
  16. MJW
    MJW
    from NJ
    1. PA. NJ. local HAMBERS group
    On my last banger with an original 94 I ran 50 jets and 6.5 power valve at sea level and it ran great. It's a little on the rich side but with the Wico mag it's better to be on the rich side than lean.
    Sent from my Nexus 6P using The H.A.M.B. mobile app
    Old Dawg likes this.
  17. RoddyB34
    RoddyB34
    Posted this in the “what did you do today “thread but thought I’d post it here too,,We dismantled the A diff from our coupe ,,it has a Hot Rod Works centre and axle conversion,,and I am goingto make a solid spacer to go between the pinion bearings so preload is solidly set ,,it will be a bit of muckingaround but may strengthen things a bit wasn’t totally happy with my carrier preload so I can redo and be sure ,,,we are running a 3.0 mercruiser so it will have a little more sting ,,my local diff guy recommended this spacer ,,,still closed drive connected to a late 3 speed all synchro top loader with a t150 Jeep shift,,
    winduptoy and Old Dawg like this.
  18. ghalperin
    ghalperin
    I've been driving my banger with all my newly installed hop up parts for about a week. I'm already over the Lakes style header. It's just not for me. I have a NOS 4 into 1 header, that must be at least 30 years old, The guy I got it from told me it hung in his garage for over 25 years. It looks pretty good quality and has spacers welded onto it for the intake.
    I'm not sure what size pipe to use and what muffler. I was recently told to use the stock muffler and pipe, that doesn't make sense to me for added performance.
    Any suggestions for pipe size, pipe length and muffler?
    ROCKER77, cactus1, Dannerr and 4 others like this.
  19. V4F
    V4F
    from middle ca.
    im using a reds 4-1 header . works well . running a single muffler & split after for dual out lets . glass packs don't live long & then its like straight pipes . with my system I have little room for a muffler . I originally built it around a porter 12" muffler (actually it was a straight thru) . I now have a (12") all metal baffled muffler . still a little loud but its ok . I think to get mine quit it would have to be a complete new system . mine comes out in front of both rear wheels . a longer out the back could have more possibities . I guess it depends on your taste & how loud you want
    it . this is mine ..………..
    stillrunners and Deuces like this.
  20. ghalperin
    ghalperin
    Thanks for the quick reply, what size pipe are you using?
  21. V4F
    V4F
    from middle ca.
    i believe the header is 2 1/2 , therefore 2 1/2" exhaust pipe .
  22. V4F
    V4F
    from middle ca.
    how does that spacer affect the races in the diff ? how does it affect pre-load ?...……… steve
  23. RoddyB34
    RoddyB34
    Hi Steve ,I presume the spacer will do the job like a crush washer does in a late model diff when collapses down to achieve desired preload and support for their pinion bearings ,,the high powered guys use a solid spacer and shims between bearings to avoid crush washer collapses ,,what are your thoughts maybe I’m overthinking this ,,
  24. V4F
    V4F
    from middle ca.
    looks like a one time set . I presume you use shims . really cool idea ………. I still have the "A" diff , so I use inch pounds for preload ……..
  25. Looking to get auto advance for my banger.
    Do you guys recommend the NuRex Automatic Spark Timing System (Mechanical Advance)
    Or an FSI Distributor?
  26. Crazydaddyo
    Crazydaddyo
    A model B distributor has centrifugal advance.
    Sent from my SM-J320P using The H.A.M.B. mobile app
    Retson the Racer likes this.
  27. On a budget built banger, would that be the smartest option?
  28. I would say yes, plus they are easy to understand and work on.
    Crazydaddyo likes this.
  29. Crazydaddyo
    Crazydaddyo
    Yes, but it depends how much you will drive it. If you plan on driving it a lot, the the FSI is your best solution.
