I am setting up a wet gauge for oil pressure and need to know if either of the ports in the picture (under masking tape) is more advantageous to use than the other? Thanks for the help.
Correct , both of my Y Blocks have petcocks in the upper hole, they are block drains. The lower holes are plugged off. The oil pressure port is located towards the rear of the engine just behind the oil filter.
As mentioned above, the lower one or the one back by the oil filter will work too Sent from my SM-G900V using The H.A.M.B. mobile app
OK. Excuse my ignorance, but are the oil "ports" pictured in the first entry plugged up? How do you access them? (Can you post more pictures?) I'm trying to add an oil pressure gauge to my 272. (In addition to the oil pressure sending unit) I'm having a problem getting a tool to remove oil pressure sending unit. No room to turn anything. Special socket I bought was too deep. Want to use a T-Pipe to run both. Thoughts? Thanks.
there is a row of plugs on the side of the engine, in line, front to back, with the sending unit. Remove one of those plugs, and put your gauge oil line there.
that is where I suggested in your post on the the 52-59 social forum that motor mount in pic is not a stock mount but the port is in same spot on your motor
