Technical Looking for a bigger velocity stack
Discussion in 'Traditional Hot Rods' started by Gus68, Oct 7, 2018.
  1. Gus68
    Gus68
    from Minnesota
    Ok. So I've been searching the nets and I just can't seem to find what I'm after. I'm looking for a velocity stack for a 4 barrel, and I see jegs and speedway and all the rest sell the same 8 3/4 diameter one. I'm looking for one that's a little bigger, like maybe 12in or 14in. Oh and the style I'm after is the one with the mesh top, not a small air filter. I figured if anyone would know, the H.A.M.B. would know!
  2. sunbeam
    sunbeam
    You might try a heating and air supplier for reducers you could modify.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    You'd be surprised how air flows thru these when you open the bottom of one. Restaurant supply store.
    fauj, mad mikey, jimmy six and 3 others like this.
  4. squirrel
    make your own. I did.
  5. Sounds like you want the old Motion Performance 12 inch flying eye
    mad mikey and loudbang like this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
  7. DDDenny
  8. DDDenny
  9. 56sedandelivery
    56sedandelivery
    I have a couple of OLD aluminum "salad bowels" I picked up in a second hand store to make velocity stacks out of. I say old, because anything new these days, is plastic or thin stainless steel; plastic does't hold up, and it's hard to form stainless steel to fit a carburetor. The aluminum is fairly easy to work with, it's soft and easily shapes to fit the top of a carburetor, and they were CHEAP. Just don't raid your wife's kitchen for anything. I am Butch/56sedandelivery.
    mad mikey, Hnstray and loudbang like this.
  10. guitarguy
    guitarguy
    Yup, not that easy to find, but you could potentially make one.
    Pic snagged from the net:
    The salad bowl was a dyno sensation as tested on Engine Masters show on Motor Trend On Demand. I think it really woke some people up on the way air prefers to flow into a carb. It was a great episode.
    mad mikey likes this.
  11. Deuces
    Deuces
    I like the one that came on the '65 GT-350R....;)
    kidcampbell71 likes this.
  12. squirrel
    the salad bowl did ok, but the normal velocity stack was better....
    think about what the air has to do to get into the carb, it makes sense. Air doesn't like to go around corners, it likes to go mostly straight. The normal velocity stack straightens it out. The salad bowl doesn't really.
    Hnstray likes this.
  13. Gus68
    Gus68
    from Minnesota
    YES!!!! The fly eye!!! I did not know that's what it's called. If I had known i would have been able to find it. Thanx guys!
    swade41 likes this.
  14. Man, I remember a friends Fairlane catching on fire with one of these breathers, the gas soaked foam element burst into flames and did a lot of damage to the hood, carburator and wires before he got the fire out, he was lucky someone came to his aid with a fire extinguisher. HRP
  15. kursplat
    kursplat
    yup, seen that. one good pop back through the carb :eek:
  16. Anything with that top is called "flying eye" motion, edelbrock or the modern velocity stack ones. I have a motion myself, that you can see sitting on the big block and a couple of the edelbrock's that are good for keeping stones out at the track. 20181008_235539.jpg 20181008_235959.jpg
  17. 41rodderz
    41rodderz
    from Oregon
    I have seen a pic of one burned.
  18. 41rodderz
    41rodderz
    from Oregon
    I was at a scrap metal yard and they had a bunch of industrial aluminum spot lights. The velocity stack came to my mind's eye back then. They were huge . Make your car look like one of those hot wheels cars of old.
  19. toxic waste
    toxic waste
    from Iowa
    RatPwrd, loudbang and kadillackid like this.
  20. Racingsnake
    Racingsnake
    from So Cal
    Anybody know where to get replacement foam for one of these air cleaners? Not sure what brand it is.
    Budget36 likes this.
  21. Your best bet is to buy a K&N type lid and trim it to fit, or buy the 11 inch one and make a ring to take up the gap. 798272-3c929011848c0efc13172842310d198f.jpg
  22. 34Phil
    34Phil
  23. Racingsnake
    Racingsnake
    from So Cal
    Thanks, I'll give those a try.
  24. zachary stotz
    zachary stotz
    I have also had this problem, but wanted to let everyone know that I will be making a prototype velocity stack to fit on a 4150 carburetor for my UMP Dirt Modified. I will be making it out of .090 aluminum sheet by cutting out a truncated cone and welding it up with a 1" flat ring on top with a flat sheet running 90 degrees from the ring on down to inside the truncated cone. This will be designed to use the K&N xstream air filter only. A 4" high stack will have a 45 degree angle down to the carb.
    If it holds up all season, at the end, I'll put it on the dyno and release the results from my old filter to the new prototype. If all goes well, i will begin selling these next fall.
  25. seb fontana
    seb fontana
    from ct
  26. Harv
    Harv
    from Sydney
    A little different, but I wanted decent ram tubes for my triple Aussie BXOV Stromberg carbs (65mm diameter airhorn). Lots of different stacks out there, but none with a fully rolled lip to improve flow (3% better flow for a 180-degree rolled edge, 5% for a 270-degree rolled edge). I ended up using turbo inlet scoops (from evilBay), cut down to size.
    Needs filtration on the street, so used some mesh from my local autoparts store and some speedway slip-on oiled foam filters.
    Perhaps could take the top section for the 4-barrel. May not work given the throat size you are looking for, but food for thought.
    Cheers,
    Harv
  27. lippy
    lippy
    from Ks
    Wow I didn't know a velocity stack was that big a horsepower maker. You really must have that combo dialed in!! Lippy
  28. Bob Lowry
    Bob Lowry
    Doesn't every guy want a bigger velocity stack?
  29. 1971BB427
    1971BB427
    from Oregon
    Those old mesh top units whether round or triangular were notorious for catching fire, and burning up hoods, and engines! The foam was flammable, and if you ever had a backfire through the carb they'd ignite.
  30. Elcohaulic
    Elcohaulic
    Those lid air cleaners are suppose to really slow air flow down... They claim the Mopar bell style air cleaner is best with a 14 x 4 air cleaner..
