Technical Zephyr gears mainshaft question
Discussion in 'Traditional Hot Rods' started by 1950mercsled, Sep 29, 2018.
  1. 1950mercsled
    1950mercsled
    Hey just Picked up some Zephyr gears cluster is 25-22-18-14
    The main drive is 19 tooth.
    Does anyone know what tooth count intermediate gear, Low and reverse, And reverse Idler these gears fit ? Thanks
  2. 1950mercsled
    1950mercsled
    These gears
  3. Mac VP
    Mac VP
    The second gear is also a unique LZ item.....it should have 24 teeth. The other gears you mentioned will be the same as the Ford transmission gears from 1939-50.
    For example, the low/reverse gear has 29 teeth and 16 splines (all helical). The reverse idler gear will have 18 teeth (all helical).
    The complete gear set would have either version (01A-7124 or 8M-7124) of the late style synchronizer. The main shaft must also be of the late style (81A-7061 or 51A-7061) or the 1942-50 version main shaft (21C-7061 or 59C-7061) if you’re going to go with an open driveshaft configuration.
  4. 1950mercsled
    1950mercsled
    Man I that is exactly what I needed to know thank you so much.
