1935 ford sedan vin location
Discussion in 'The Hokey Ass Message Board' started by shelby69500, Sep 19, 2012.
  1. Jeff Pandora
    Jeff Pandora
    from Mojave
    Nice 40 like it ... well the front stamp has been replaced and it has different font than middle and rear However all numbers match I look around the area to see if i could see ant more numbers nothing there I due appreciate all your help on this . I will try to register with the DMV in California and see how it goes bill of sale only this otta be fun the person I purchased it from said it had a 35 cabriolet on it if that helps
  2. 1946caddy
    1946caddy
    from washington
    The way I understand it is that the full number including the 18 is used on the front and the middle and rear only used the last seven numbers omitting the 18. Your front number should read 18168xxxx
  3. Jeff Pandora
    Jeff Pandora
    from Mojave
    thanks ... I think my math might be rusty when I look at the numbers that would make a 1932 frame and its not that well I don't think so Did they make 32 frames with out the stamp ridge on the bottom ?
  4. 1946caddy
    1946caddy
    from washington
  5. Jeff Pandora
    Jeff Pandora
    from Mojave
    Thank you the missing 18 throws me off so I keep taking off the 16 ..
