Ok trans shifter is killer but the one thing everyone is over looking here is the fact you got it hooked to a v12!!!!!!!!!!!! Sent from my iPhone using The H.A.M.B. mobile app
Got the rear window wood sorted. I got the wood in a trade, so we didn’t have to make it. Sent from my iPad using The H.A.M.B. mobile app
Yeh, I’ve been toying with the idea of stretching the frame and hood a little also. Sent from my iPad using The H.A.M.B. mobile app
enjoying this keep the updates coming, I'm an ol skool carpenter from England so the wood work is my thing
Looks like the wood went to a good home! Looking good! Sent from my SM-G930V using The H.A.M.B. mobile app
I measured a stock setup from the front of the engine and then left enough room for the firewall. I can manipulate it around the dash as needed once I get there. I think it will still be aft of the stock setup. Sent from my iPad using The H.A.M.B. mobile app
I’ve been working on parts for both the coupe and the roadster project Sent from my iPad using The H.A.M.B. mobile app
Did this a while back. I had one nice door garnish, that came with the body. Took a pair of 4-door moldings and...presto.
Thanks, I got it from a fellow H.A.M.B.er... don’t know original origins Sent from my iPad using The H.A.M.B. mobile app
Made the wood for the seat and assembled Replaced the bolts in the seat rails Sent from my iPad using The H.A.M.B. mobile app
Getting ready to build up some floors/bodies. I posted pictures of the rotisserie I built in my roadster thread also. Still need some bracing Sent from my iPad using The H.A.M.B. mobile app
Started working on the floor. I thought I would be able to use the subrails, but in the end I cut them off and will use reproduction. It’s not the best floor, but it’s clean...I had it media blasted a few years ago. Couple more bullet holes Sent from my iPad using The H.A.M.B. mobile app
