Hot Rods Looking for a steel reverse wheel for early Ford. Just one.
Discussion in 'The Hokey Ass Message Board' started by willishotrods, Sep 13, 2018.
  1. willishotrods
    willishotrods
    Anyone ever seen one of these or know where I can find one or someone who can make one. They were on my 40 Ford back in the 50’s but one was lost.
  2. BJR
    BJR
    Is that a Merc wheel? We used to knock out the rivets and reverse the center, and re rivet or weld the center back in. After putting it back on a front spindle and checking for runout before welding. Looks like that was a home done wheel, as the valve stem is now on the inside.
    Hnstray, 54vicky and chryslerfan55 like this.
  3. willishotrods
    willishotrods
    It is a home built wheel for sure but not sure if it’s mercury or Ford. That’s what I’m hoping to find out.
  4. Bruce Lancaster
    Bruce Lancaster
    Don't the hubcap bumps on outside of center suggest Merc? I'm assuming '40-48 Ford, '49-50 Merc comparison.
    Hnstray and willishotrods like this.
  5. adam401
    adam401
    For reference here's a stock merc wheel.
    Hnstray likes this.
  6. willishotrods
    willishotrods
    Thanks for sharing that photo. I need to pull my wheel off and get a photo of the inside.
  7. fortynut
    fortynut
    You must also remember that many of the early reversed wheels used a Ford center and a Buick outer. To my old eyes that is what the 'reversed one you have appears to be. Also, with Forty rims the hubcap is held in place from the inside. And, 16" inch Forty rims are on the endangered species list. My advice is to buy two reversed style rims from a reputable wheel Smith, or have a pair made. The chances of getting another 'just perfect' match is not going to be easy. PLUS, there are safety issues at play with modern highway speeds, not faced 'in the old days'; this in addition to straightness and wheel and tire balance. No matter your choice: Good Luck & Safe Driving.
    olscrounger likes this.
  8. 302GMC
    302GMC
    from Idaho
    Reversed '49-'51 Merc. Find another stocker & reverse it ….
    clem and timwhit like this.
  9. This may not help much but the wheel on the left is an early ford center (not just like yours) but is in a Buick outer rim. Currently on the back of my sedan. 023.jpg 023.jpg
  10. the f100 trucks used the same bolt pattern as the merc.
    Johnny Gee likes this.
  11. willishotrods
    willishotrods
    I appreciate everyone help. I plan to reverse another one to match the original. Just trying to find out what original rims I need to find. These were with the car since the 50’s so I would like to keep them.
  12. swifty
    swifty
    302GMC three posts up has your answer but beware as only the Merc caps from those years will fit those wheels as the cap nubs are bigger diameter than the Fords.
  13. 302GMC
    302GMC
    from Idaho
    You'll occasionally find the Merc wheels with 3 or 4 round head 1/4''-20 screws in the web to hold early Ford hubcaps. Saw 1 with 3 blobs of weld that worked fine. I remember the '50 Merc caps were almost impossible to find used, but '49s were everywhere.
  14. willishotrods
    willishotrods
    Here's a couple images from 62 with the wheels on the coupe.
  15. willishotrods
    willishotrods
    I've had this old Ford coupe for 30 years now. Im ready to get some progress.
    302GMC likes this.
  16. 40LUV
    40LUV
    from Mid Jersey
    Is that the same '55 too from '62?
  17. willishotrods
    willishotrods
    No thats a 57 hardtop. The 55 is long gone.
