Hot Rods Save of the day!!(single seater)
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Mar 14, 2017.
  1. rusty rocket
    rusty rocket
    Holy Crap thats Kool!!!!!!
  2. rusty rocket
    rusty rocket
    brEad, kiwijeff and Okie Pete like this.
  3. rusty rocket
    rusty rocket
    I had my buddy tig up my steering box extension so I was able to mount the box and poke a hole thru the cowl. IMG_3194.JPG IMG_3195.JPG IMG_3196.JPG I also started ruffing out a dash so I can mount my steering column to it. IMG_3197.JPG IMG_3198.JPG IMG_3200.JPG
    brEad, kiwijeff, brad2v and 9 others like this.
  4. rusty rocket
    rusty rocket
    kiwijeff, Okie Pete, brad2v and 6 others like this.
  5. rusty rocket
    rusty rocket
    Had an old tie rod laying around for my drag link but it was three inches to long. I cut it off and borrowed a buddies 11/16 right hand tap. Holy cow what a bitch to tap but I got it. IMG_3209.JPG IMG_3210.JPG
    tb33anda3rd, brEad, Okie Pete and 8 others like this.
  6. Gavin Tittle
    Gavin Tittle
  7. rusty rocket
    rusty rocket
    Sometimes what seems to be a simple project takes forever and fights you all the way.
  8. Gavin Tittle
    Gavin Tittle
    You can say that again! I watched my buddy drop a washer down the distributor bore in a 289 Ford I have in a car I’m building.... talk about an easy job getting real hard real quick
    Stogy likes this.
  9. rusty rocket
    rusty rocket
    I havent been getting much done lately on the car. I wanted to fill the holes in the frame but didnt want to weld them shut so I turned carriage bolts down on the lathe and I found some sickle bar rivets at my local farm supply store.
    I like the looks of the bumps on the side of the frame. IMG_3229.JPG IMG_3230.JPG IMG_3237.JPG
    Greenblade, brEad, kiwijeff and 10 others like this.
  10. I'm so envious of all the fun your having... :)
    Greenblade and Stogy like this.
  11. rusty rocket
    rusty rocket
    It has been a fun little project. The only rule I have is to make it safe other than that the rule book has been thrown out the window.
    BigO, Stogy and Jet96 like this.
  12. cederholm
    cederholm
    Damn I love this car!
    BigO likes this.
  13. rusty rocket
    rusty rocket
    I had to make clearance for my driveshaft but couldnt move my seat riser. I used a piece of wood clamped to the pipe to guide the hole saw. IMG_3251.jpg IMG_3253.JPG IMG_3254.JPG IMG_3255.JPG
  14. gdaddy
    gdaddy
    from nw fl.
    that is a good ideal , the hole saw and wood for a guide , love the build .
  15. rusty rocket
    rusty rocket
    I got my floorpan/footwell mounted to the bottom side of the frame. I think my last big hurdle will be clutch and brake pedal placement. IMG_3262.JPG IMG_3263.jpg
  16. Blues4U
    Blues4U
    from So Cal
    Dude, I love that flat track style XS650!
  17. rusty rocket
    rusty rocket
    Ha, want to buy it?;)It needs to find a new home.
  18. Blues4U
    Blues4U
    from So Cal
    So it could join the other bikes just sitting around here and not getting ridden? No thanks. ;) Still a cool bike though.
  19. rusty rocket
    rusty rocket
    That is exactly what happens here. I need to get off my ass and put a few things for sale on the net.
    Blues4U likes this.
  20. rusty rocket
    rusty rocket
    Out in the shop and I needed a bit of help lifting my frame on the bench but I couldnt get these gals to lend a hand. IMG_3261.JPG IMG_3259.JPG I guess I will not be calling my shop Wild Turkey Hot Rods!!
  21. rusty rocket
    rusty rocket
    I built a set of hinges so I can flip the seat forward to access the back to the tail section. IMG_3270.JPG IMG_3266.JPG IMG_3267.JPG IMG_3268.JPG
    tb33anda3rd, brEad, kiwijeff and 9 others like this.
  22. Nice! I love that seat man.
  23. Blues4U
    Blues4U
    from So Cal
    Are you going to latch it down some way? I'm going to install new seats in my model A and am thinking of installing a hinge in front so they can flip forward like this, to access behind them, but I'd want them latched when in the down position.
    Stogy likes this.
  24. Love the simplicity of those hinges,great idea using a piece of angle then craving it up.
    Plus the hole saw guide,I’m sure these will be copied by a lot more people than me.
    brad2v and Stogy like this.
  25. rusty rocket
    rusty rocket
    Yes I will come up with some kind of latch for the back, just have to stew on it for a bit and see what I come up with.
    Thanks, its different but fits the build.
    Stogy likes this.
  26. rusty rocket
    rusty rocket
    Thank man, Angle Iron seems to be my go to I used it to build my hurst style motor mount, part of the footwell/floorpan and now seat hinges. Just cut it up and throw a few curves on it and it doesnt look like angle iron.
    brEad likes this.
  27. rusty rocket
    rusty rocket
    I did some minor crack repair,paint and friction tape on my 39 chevy wheel to give it the race car vibe. IMG_3278.JPG IMG_3279.JPG
    Okie Pete, brad2v, Stogy and 4 others like this.
  28. ...for seat latches, how about a couple screen door hooks,,,you can get threaded eye hooks to bolt em down...hey (my) steering wheel looks rite at home in there...nice work on that lil car...
  29. rusty rocket
    rusty rocket
    I have an idea for a little spring latch for the back of the seat.
    Yes your old wheel does look pretty darn good in there.
    Stogy likes this.
  30. Oh man I see a heater in that shop. I'm hecka-jelly! It got cold here today. Wheel looks good!
    Stogy likes this.
