I got the 4 door to use the chassis for the 3 window.... Sent from my iPad using The H.A.M.B. mobile app
Fitted the new lower b-pillar brackets. I got these from Steve at SAR, traded an extra set of trunk hinges for them. Sent from my iPad using The H.A.M.B. mobile app
Spent the morning drilling the hinge pins out of the doors in preparation for attaching them to the b-pillars. I ended up having to remove four of the hinges from the doors and straighten them out on the press. Once the hinges were sorted, did some adjusting of the gap (sanding the wood) and installed the hinges on the b-pillar Sent from my iPad using The H.A.M.B. mobile app
Finished mounting the hinges on the second b-pillar. The door tins that came with the car are very nice except the bottom 8 inches. I made a template and bent the new bottoms. Mew metal installed Gave all the bare metal a quick coat of primer and assembled everything. Sent from my iPad using The H.A.M.B. mobile app
I do also, but I’ve been thinking lately that I’d like a project that came with the doors on. Sent from my iPad using The H.A.M.B. mobile app
Looks good Bjorn, thanks for the '32 shocks I installed them last week on the '32 roadster chassis after I aged them some to match my original chassis
Thanks, glad they worked out for you. I’ve been jumping around between projects...worked on my 32 today, but it’s not H.A.M.B. friendly so no thread. Sent from my iPad using The H.A.M.B. mobile app
Wanted: Looking for a picture of the three window wood installed similar to this five window picture. Sent from my iPad using The H.A.M.B. mobile app
Worked on the top bows and dome light mount. Was able to use the four door bows and mount as a template and scale them down a little. Sent from my iPad using The H.A.M.B. mobile app
I was able to get the picture I needed from a car advertised on eBay Sent from my iPad using The H.A.M.B. mobile app
Thanks, I’m back at it for a couple months...but I have several projects, so this one doesn’t get full time. Sent from my iPad using The H.A.M.B. mobile app
That’s one interesting bit of engineering on that shifter, does it work well? If it does, might have to steal that idea :–) Sent from my iPad using H.A.M.B.
Nah... you're thinking of TROG. That combo is completely HAMB friendly!!! A LOT of cars on here have overdrive transmissions... since they're hidden. I love the shifter too! I hope it works out for ya! 3blap.
