hi i don't know why but my clutch won't disengage. If i rotate the clutch shaft to the max it just touches the 3 bolt for disengagement i have French flathead and a 39 tranny with a new release bearing. can anybody tell what's wrong? is the french pressure plate incompatible? pictures show the clutch shaft in released position. thanks Jan
I went nuts for over a year with a similar problem. Turned out to be a transmission was from a 6cyl flathead. The case is different. To check, look for a 1/4 hole in the bottom of the case.For a V8 case, this hole allows you to insert a long drift to drive out the pin in the throwout bearing fork. If that hole isn't in the bottom of the case, it's a 6cyl. trans
Does the French pressure plate look like a Ford 3 arm stock plate? I think it might be the pressure plate is not compatible with the Ford disc.
Well, you didn’t say what vehicle this is in. How about a shot of the pedal and linkage setup you have? Maybe a combination of the wrong linkage parts. Cliff Ramsdell
the clutch fingers are up against the candle stick, they aren't even close to the throw out bearing ! Looks like the pressure plate is wrong , the fingers are to long & to close to the center !
Pete makes a good point. Looking at the picture closer the fingers could be hitting on the inputshaft retainer. Maybe the pressure plate is for a 1 1/16” input shaft and not the. 1 3/8” that the flathead uses. Cliff Ramsdell
