Technical Package Tray on a 32 roadster
Discussion in 'Traditional Hot Rods' started by magnus13, Sep 4, 2018.
  1. magnus13
    magnus13
    What's the purpose of the package tray on a 32 roadster? I have a Brookville body and it came with one. Other than welding it in place and using it to finish the edge to roll into the cockpit, I can't figure out what that horizontal ledge is for. Is that where the seat back mounts to?
    I'll be going with a Bengels seat soon so I don't think I'll need this. What do you guys do with this?
    Thanks
    Sent from my SAMSUNG-SM-G891A using The H.A.M.B. mobile app
  2. Toss em in the scrap bin
    Your legs will thank you
  3. It does help stiffen the body
    We reinforced the body underneath/ behind where that panel welded
  4. DDDenny
    Coupe has a "package tray", never heard of a roadster using one, where would it go?
  5. That’s what I was thinking too
    I looked it up and it’s listed that way but it’s not near as wide as a coupe
    Looks like something to mount the seat
    Must be why we never used it
  6. magnus13
    magnus13
    Me too. I was wondering why they sent one with the body.
    This thing?
    X38 likes this.
  8. magnus13
    magnus13
    Yes. It looks like you could weld that in and smooth the lip over into the cockpit, then slice off that horizontal ledge...if I were to use it.
  9. Deuce Lover
    Deuce Lover
    Basically it supports the original seat back wood frame.
    Flop, micksmith and X38 like this.
  10. micksmith
    micksmith
    from australia
    2nd from the top is a Aussie one which is basically the same as a American hope this helps Sheldon is correct in his post Above
