Technical Period correct supercharging
Discussion in 'Traditional Hot Rods' started by NielsK, Sep 2, 2018.
  1. NielsK
    NielsK
    from Denmark
    Hi guys. I have a nice sweet running Nash Standard Six. It'll end up in a T.R.O.G. style car. Light body, some kind of speedster body. As you probably know there are no speed parts for a Standard Six. But with 7 main bearings and fully pressurized oiling system it almost screams: "Supercharger" at me. Here goes: What options do I have? It has to be pre '48 to comply with the rules. And you UK guys please chime in. I know a lot of UK based "specials" where supercharged. If anybody has an idea where to souce a good example. . . That would be appreciated
    Sent from my SM-G930F using The H.A.M.B. mobile app
    kidcampbell71 likes this.
  2. What year did the GMC blowers start ?
  3. Rusty O'Toole
    Rusty O'Toole
    You are on the right track, those old mildly tuned low compression engines respond well to supercharging especially the centrifugal type.
    McCulloch made blowers for Ford in the 1930s. There were centrifugal blowers on Graham, Auburn, Cord and Duesenberg cars in the 30s. Graham superchargers turn up from time to time. There was a long, long thread about a Ford tractor 4 banger with one in the TROG, I suppose you have seen it.
    The popular VS57 did not debut until 1953. But it has a vintage appearance and can be adapted to many engines.
    There were European made aftermarket superchargers like Centric, Judson, and others. Where you would find one I don't know. Most of them were made for engines under 2 liters.
    You might be able to take a turbocharger off an old diesel truck and modify the blower section into a belt driven supercharger.
  4. Rusty O'Toole
    Rusty O'Toole
    Graham straight eight supercharger
    From the other side
    McCulloch for 30s Ford
    McCulloch VS57 on a Ford flathead
    You get the idea. It may be possible to find a vintage supercharger in Denmark, if not you should certainly be able to find an old turbo you can modify.
  5. Relic Stew
    Relic Stew
    from Wisconsin
    Some more pictures of vintage superchargers;
    Alpha Romeo
    I think this is a Miller impeller,
    classiccarjack and Jet96 like this.
  6. drtrcrV-8
    drtrcrV-8
    Rusty : Judson was made in Conshohocken, PA( a suburb of Philadalphia )
  7. Rusty O'Toole
    Rusty O'Toole
    Sorry for the confusion. I remember the Judson being advertised in sports car magazines in the fifties for MG, VW, Triumph etc and assumed it was imported.
    The Powerplus was a similar design made in England. I believe SCOTT superchargers were made in Italy. Is the OP going to find a suitable vintage supercharger in Denmark? You never know your luck.
    In any case I recommend the centrifugal type as being the simplest, lightest, and best suited to mild hop up of a road going engine. It doesn't do much at low RPM, where vintage engines are strongest, but helps a lot at medium to high speeds where they start gasping for air.
  8. NielsK
    NielsK
    from Denmark
    I really like the idea of modifying an old turbo. . Problem will be complying to the pre 48 rule. I have a lead on 2 small Rootes type blowers. They' ve run on a 1.5 liter Riley. Thinking of running them in tandem. They need a lot of work though
    Unkl Ian likes this.
  9. Rusty O'Toole
    Rusty O'Toole
    This is too obvious but if you hop up an old engine you must be sure the bearings, rings, pistons, oiling system etc are in top shape or your engine will have a short life, if a merry one.
    With a centrifugal supercharger you can get a horsepower increase of 30% to 40% and never hurt the engine. This supposes a blower pressure of 4 - 5 pounds. The American cars that had superchargers, considered this pressure perfectly consistent with the use of ordinary pump gas, and did not hurt driveability or engine life. But it certainly adds a lot of oomph where you need it most.
  10. Rusty O'Toole
    Rusty O'Toole
    Why pre 48? Are you planning on shipping the car to New Jersey for the TROG?
  11. NielsK
    NielsK
    from Denmark
    Super nice pics by the way I would love a Graham or a Frenzel
  12. Rusty O'Toole
    Rusty O'Toole
  13. studebakerjoe
    studebakerjoe
    Unkl Ian the GMC blowers were out in 1938 on the 71 series engines.
  14. NielsK
    NielsK
    from Denmark
    Thanks. That was what I expected. I found a Kaiser Frazer on E . . . But somehow I can't image it in my engine bay, it's hideous Not that pricey though. I'll try and wrestle the 2 Roots type blowers from a old geezer I've met recently. They need a lot of work. But they would look killer in tandem hanging on the side of that old green six cylinder
  15. NielsK
    NielsK
    from Denmark
    Wow I didn't know that. I've always thought they popped up in the early fifties
    chris13mel and Unkl Ian like this.
  16. Deuces
    Deuces
    I'll take a 6-71 with a Hilborn 4 port injector.....
    gimpyshotrods likes this.
  17. gimpyshotrods
    gimpyshotrods
  18. gimpyshotrods
    gimpyshotrods
    Looking for a throttle body now.
    rdscotty and Deuces like this.
  19. rusty rocket
    rusty rocket
    I dont know much about superchargers except you probably need to run a chain drive:)
    Just Gary likes this.
  20. NielsK
    NielsK
    from Denmark
    Thought of that. It would scare my pants of everytime I rev it up and that chain starts to "sing". Naaah I would be stupid enough to try it
  21. Rusty O'Toole
    Rusty O'Toole
    Leave the Riley superchargers to the Riley fans. You can do better. For your purpose a centrifugal blower is better than a roots.
    NielsK likes this.
  22. topher5150
    topher5150
    NielsK likes this.
  23. topher5150
    topher5150
    also any other cool crank driven supercharger
    NielsK likes this.
  24. banjorear
    banjorear
    Yep. When I was kid and was fooling with VW's, the Judson was the set-up. Everything fit under the hood. It allowed those 1200 CC's to actually climb a steep hill in 2nd gear. LOL!
    NielsK and VANDENPLAS like this.
  25. Inline
    Inline
    from Ohio
    I put a Graham Supercharger on my roadster about 15yrs ago. It producrs just over the amount of power it takes to run it. They are certainly neat pieces...
    It's on a '37 Dodge 218 w/ a 5 speed.
    Sent from my SM-G930V using The H.A.M.B. mobile app
    NielsK and classiccarjack like this.
  26. sunbeam
    sunbeam
    NielsK and Hnstray like this.
  27. Speed Gems
    Speed Gems
    Jet96 likes this.
  28. nutrocker
    nutrocker
    I believe the Wade company started making blowers in ‘47 although the RO34 didn’t get fitted to the Commer TS3 till ‘53. A bit of research might find the RO34 and it’s little brother the RO20 used a lot earlier.
    Interestingly, the roots type blower like the RO34 make really good low down efficiency. As high as 90% efficient low down but dropping to 70% around the mid range revs and boost and then a massive drop to 50% at the higher revs.
    The setup I have produces a full 10 lbs of boost (according to my boost gauge) when driven at 1:1 engine speed and gives boost really low down.
    The angled intake/output flanges is due to having straight rotors. The idea is to even out the pulses that the straight rotors produce.
    NielsK and Jet96 like this.
  29. classiccarjack
    classiccarjack
    @Inline...
    I would love to see pictures of your 1937!
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  30. fullhouse296
    fullhouse296
    from Australia
    An easy /cheap and great looking setup is the Wade RO34 .It already has the curved outlet underneath which makes it easy to fab the intake .Also, the rotors dont need pins . Look for old pommy Commer trucks with the flat four two stroke engine . Looks quite like a Scott .
    NielsK likes this.
