Hot Rods Qucktime for 390 Cad.....anyone???
Discussion in 'The Hokey Ass Message Board' started by DeadFast 33, Nov 8, 2017.
  1. DeadFast 33
    DeadFast 33
    from Santa Cruz
    I’ve got a wilcap adapter behind my 390 now but I ran across the QuickTime and they look a lot less bulky and of course extra safe compared to an aluminum bellhousing. The motor is in my 32 vicky and any extra floor room is nice!!!
    Does anyone here have any real world experience with this combination?
    Thanks,
    FLiP
    @eights_aces_flip on Instagram
    Www.eightsandacestattoo.com
  2. DeadFast 33
    DeadFast 33
    from Santa Cruz
    .......I’m guessing that’s a NO???
  3. Any Pics?Interested in seeing this.
  4. ls1yj
    ls1yj
    from Kentucky
    Deadfast33
    I’ll send you some pics... I have a QuickTime for my 331, and it fit up great... engine is on stand now, but Its profile is narrow compared to adapters
  5. ls1yj
    ls1yj
    from Kentucky
  6. DeadFast 33
    DeadFast 33
    from Santa Cruz
    Thank you ls1yj for not only the response, but the pictures!! Overall it looks like a better fit than adapters!!! What part number did you use? They only offer one I think?
    Thank you again.
    ls1yj likes this.
  7. ls1yj
    ls1yj
    from Kentucky
    I can’t remember the part number, but like you said, they only list the one for 365-390 cads 55-62
    DeadFast 33 likes this.
  8. ls1yj
    ls1yj
    from Kentucky
    Part number is RM 8025
  9. Thanks also for the pics,they look top quality.
    ls1yj likes this.
  10. ls1yj
    ls1yj
    from Kentucky
    Here’s a pic without T-5 [​IMG]
    And a pic of scaled quick dimensions
    Torkwrench likes this.
  11. DeadFast 33
    DeadFast 33
    from Santa Cruz
    Definitely looks like no Muncie/ t5 GM pattern......bummer.
  12. ls1yj
    ls1yj
    from Kentucky
    Deadfast33,
    If you were feeling adventurous, the mount plate is healthy 3/8 HRS, and could be altered with some ears to give you room to add hole pattern you need
    DeadFast 33 and Zerk like this.
  13. Pete
    Pete
    I had no idea these existed.
  14. mgtstumpy
    mgtstumpy
    You'd be a lot more confident that it is SFI rated, that new T5 should easily handle the torque of your Caddy mill. Very nice. You wouldn't have an issue in selling that Wilcap kit to offset and recoup your outlays.
    ls1yj and DeadFast 33 like this.
  15. DeadFast 33
    DeadFast 33
    from Santa Cruz
    I reached out to the makers of the bellhousing and I’m seeing about them making a run of housings with the Muncie/t5 bolt pattern. Who know? It might happen??
    Tim and ls1yj like this.
  16. Hey DeadFast, the RM 8025 is for 390 Caddys...did you end up getting one? Just like everything else Cadillac, atleast twice the price of everything else they sell.
    ls1yj likes this.
  17.
    ls1yj likes this.
  18. ls1yj
    ls1yj
    from Kentucky
    Deluxe32,
    I found a 132 toothed steel billet flywheel that will work with this setup
  19. Do you know who made it or what its original application was?
    Sent from my SM-J320ZN using The H.A.M.B. mobile app
  20. ls1yj
    ls1yj
    from Kentucky
    Give Tom a call at Wilcap Adapters.he made it for me
    DeLuxe 32 likes this.
  21. jimmy six
    jimmy six
    QuickTimes are way better than the Lakewood styles. That 1/2" thick plate allows for additional trans mounts. I would have no problem making additional "ears" and welding them to the plate. The measurement of the trans snout for the clutch must be right along with the hole diameter. Alignment rings are not that hard to make either and could be available from QT.
    They actually make some that do not have the SFI ratings and would be fine for any of our street cars.
    ls1yj likes this.
  22. Torkwrench
    Torkwrench
    This looks really interesting.
    ls1yj likes this.
  23. Unfortunately like everything else Cadillac, twice the price it should be.
    ekimneirbo and ls1yj like this.
  24. DeadFast 33
    DeadFast 33
    from Santa Cruz
    I didn’t, and l haven’t perused getting them to make one for a gm t-5. I’ve been busy with other stuff and have kina dropped the ball.
  25. ls1yj
    ls1yj
    from Kentucky
    Just wanted to throw a lil blurb
    out about the sketch I put up awhile back... it was just a quick scaled drawing, to see if a guy’s T-5 would fit this model and hole pattern... I did not take great care to get precise dimensions, so I’d recommend getting a machinist or other to grab a little better numbers before doing any machining.... sorry for any confusion
  26. rexrogers
    rexrogers
    What flywheel and clutch set up did you use? I have a 390 and the quick time bellhousing on a 32 5 window project and now its time to figure out all that out.
    Wilcap said there flywheel is 1.2" thick from crank to friction service. Is that the same flywheel you used?
  27. rexrogers
    rexrogers
    ls1yj likes this.
  28. ls1yj
    ls1yj
    from Kentucky
    I bought the Wilcap flywheel. It’s small, 10” clutch, 132 teeth I believe, but works with late model Chrysler truck starter
    rexrogers likes this.
  29. The only thing I've heard is the Quicktime bells can be a bit sketchy about crankshaft/trans input alignment, so do check the runout. You can get offset dowel pins for correction.
  30. rexrogers
    rexrogers
    Thank you for the information. I think i will get the flywheel from Wilcap today.
    Im working on getting everything mocked up now, trying to decide on either a mechanical clutch linkage or an external slave cylinder. I have never had much luck with a hydraulic throwout bearing.
    I like the quick time bellhousing mainly because of the size and a pretty straight forward set up. I will check the runout.
    ls1yj likes this.
