Technical Did all '32's have HEAVY front axles?
Discussion in 'Traditional Hot Rods' started by The37Kid, Oct 16, 2017.
  1. clem
    clem
    Same as 3rd pic down in post 24
    Spoggie and Hamtown Al like this.
  2. Wheeliedave
    Wheeliedave
    Are you saying that all 1932 Ford cars and trucks had what is known as the "heavy" axle ?
    I do know that my "32" passenger car was an unmodified original that had/has the "Heavy" axle which has the 2 and 3/4 inch axle bosses where the wishbone assembly attaches.
    I also know that 1933-34 Ford cars and pickups had a front axle that looked more like a model A axle but had wishbone bosses that measured 2 inches. The Model A wishbone bosses were, I believe, 2 and 1/4 inches.
    From what I have read, the 1933 axles were used through 1936 in passenger cars and light trucks.
    I also have a friend that owns a 1.5 ton truck that is all original and I believe it has axle bosses that are 2 inches.
    You do know that Henry made many changes, right?
  3. Wheeliedave
    Wheeliedave
    I screwed up! I meant 2 and 1/4 inch axle bosses, not 2 and 3/4 inches where the wishbone attaches.
  4. BJR
    BJR
    This body has no cowl vent and has side vents. What's up with that? Europe only? 32 Ford French chassis 1.jpg
  5. clem
    clem
    ^^^^ Modified by a hot rodder .........?
    kidcampbell71 likes this.
  6. Rusty O'Toole
    Rusty O'Toole
    Pretty well all American auto companies had Canadian plants. It allowed them to dodge import duties. So they made cars for Canadian and British Commonwealth countries here.
    But, they only made about 1/10 the number of cars they made in the US. So they would share parts to cut costs. Most likely they had a foundry and machine shop set up to make the 32 "heavy" axle and just kept using the old tooling as long as possible. It would have cost too much to make new dies, for the small number of axles they were making, the savings in metal would not have been worth it.
    There are a lot of little differences on Canadian made cars of all makes and often they are for reasons of cost and production convenience, and to avoid spending money on tooling new parts.
  7. Ric Dean
    Ric Dean
    from Central NY
    Hey clem
    Where do you find the number is it stamped or embossed?
    thanks
  8. clem
    clem
    Embossed, between perch bolt hole and king pin hole, both sides, but on opposite ends, same number and place as heavy axles, but have seen some without the number, yet identical in every other way, - suggesting the replacement axles ?
    Ric Dean likes this.
  9. clem
    clem
    I suspect that in certain parts of USA, mostly or only heavy axles were used, but else where, possibly mostly overseas, there were lighter ones used also.
  10. RoddyB34
    RoddyB34
    image.jpeg According to Gary Page (Aussie axle dropper) the bottom axle is known in Australia as a Canadian 32 axle,,he's only seen a few in his years of repairing and dropping many axles ,,it's noticeably slightly wider in the beam web ,you can see the slightly different shape in the pic between the perch bosses ,,as our Ford products came through Canada anything is possible here,,
    Spoggie and Ric Dean like this.
  11. clem
    clem
    On mine,
    15mm narrower on the light one , measuring between perch holes, - I couldn’t figure out why my spring seemed too long !
  12. edwardlloyd
    edwardlloyd
    from Germany
    That's a very early chassis. First few hundred.
    Sent from my SM-G935F using The H.A.M.B. mobile app
  13. edwardlloyd
    edwardlloyd
    from Germany
    Here's a British made '32 Ford made in 1933 or 34. It has the skirted front fenders which identify it as 33 onwards.
    This has the 1933 axle. Again it has it now. Maybe it was changed. 20170303_121010.jpeg 20170303_120955.jpeg
  14. Here is one sample of an axle with a forged part number.
    kidcampbell71 and The37Kid like this.
  15. Wheeliedave
    Wheeliedave
    No. My '32 had not been touched since it was built and it has the "Heavy" axle. It also has the 4 cylinder engine, all stock.
  16. clem
    clem
    I have never seen one like that before.
    Certainly different, and looks to have the embossed part number in a different place again.
  17. clem
    clem
    172989F1-CFE5-47AA-8BC7-261F608792D4.jpeg BFF1EBFC-09E8-4125-8D52-3FBC9365C875.jpeg
  18. clem
    clem
    As requested, please see in post 47 above.
  19. sloppy jalopies
    sloppy jalopies
    Memory says '28-'29-'30-'31, '33-'34 were the same and used the kingpin spacer... '32 was thicker and didn't use it...
  20. sloppy jalopies
    sloppy jalopies
    self explanatory int it ?
  21. Fordors
    Fordors
    No. Tell us more.
    RICH B likes this.
  22. sloppy jalopies
    sloppy jalopies
    when I last ran a straight ex the "king pin and bushing" sets had a washer like spacer that all but the '32 used...
  23. alchemy
    alchemy
    Sloppy, all the king pin sets come with the thin shims to take up the slop between the axle and spindle. Every year set could have slop, so the shims might be needed. Doesn't matter which year.
    Spoggie likes this.
  24. clem
    clem
    I thought that there may have been some comments on the ‘32 “light” axle with the ‘32 part number shown, that I posted, in post 47.
    After 30 plus years of being told that there is no such thing, and many interesting discussions, I thought there would be some discussion on my post.
    But alas.........
    Charlie Stephens likes this.
  25. @clem The B 3010 part number was used for all variations of '32-'36 axles, as far as I have seen.
    alchemy likes this.
  26. clem
    clem
    Thanks for your comments.
    I’ve seen the above axles both with, and without the part numbers.
    Seems like we will never know for sure.
  27. Okay. In the Ford Motor Company Parts Price List effective December 20, 1932, the front axle part number listed is B-3010 for both Model 18 and B.
    $5.50
    clem likes this.
  28. Deuce Lover
    Deuce Lover
    Apparently what out from a very knowledgeable '32 person it is a service replacement part mainly used for overseas markets in early '33.Not all axles had the embossed part number.Of all the 32's in the museum auction in Amsterdam 1 had the 33 style axle.
    clem likes this.
