Technical 1932 Ford 5w coupe roof insert...How I did it.
Discussion in 'Traditional Hot Rods' started by Standard32, Jul 20, 2018.
  1. paul55
    paul55
    from michigan
    Nice job. Back in the 80's we did a '34 sedan and that's how it was recommended at the time. I think we used 2x3s, though.
    Standard32 likes this.
  2. Well done ! Annnnd... you did it yourself !
  3. primed34
    primed34
    Small world indeed.
  4. Standard32
    Standard32
    from LA
  5. clem
    clem
    That is one cool coupe.
    And a great tech thread on how you went about the roof insert.
    Thanks for posting.
  6. Standard32
    Standard32
    from LA
    Yeh, the 3w is different. The United Pacific is $400...much cheaper than an original and I've heard they are good quality too.
  7. Standard32
    Standard32
    from LA
    Thanks... check out what's on the wall in my shop!!!
  8. Jethro
    Jethro
    Nicely done!....Thank you!
  9. Standard32
    Standard32
    from LA
    Sorry, I don't know anything about the aluminum pieces. Maybe timwhit or someone else will see this and reply. I would check places like Macs... I'm sure shaping them to fit is a pretty trick process. Unfortunately, the originals are basically impossible to find. LeBaron Bonney is who you want for materials for original style insert. I JUST finished this a couple days ago and made the video...But, yes I'm sure there will be wind noise. It's just a necessary evil if you want the original style.
    HemiDeuce likes this.
  10. qwkchevy
    qwkchevy
    Great video I hope to own a vehicle like this soon and this is very helpful. Thanks for taking the time to document and share.
    Sent from my LG-H910 using The H.A.M.B. mobile app
  11. 3blapcam
    3blapcam
    Thanks for the video... I also plan on re-installing an original style insert, and I'm not quite there yet. I will re-watch the video prior to install though!
    3blap.
  12. Great job and great video. I too will rewatch when it's time to do my 3wd.
  13. Mike Colemire
    Mike Colemire
    It was great, almost as cool as the car! I saved it, I'm still on the fence on cloth insert, which I like the looks better, or solid metal.
  14. primed34
    primed34
    I don't notice any noise with my insert, but my wife says I don't notice any kind of noise.:D
  15. scotti32
    scotti32
    Great video thanks. Awesome coupe.
  16. rustymetal
    rustymetal
    great job explaining how too and very sweet coupe
    thanks for sharing cheers
  17. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Great Video. I have done several and take a little different approach. Instead of chicken wire I use 1/8 inch waterproof tempered Masonite cut to fit the hole and screwed to the wood with countersunk flat head screws. Some times you have to sand the edges a little for the right fit. I then cover the Masonite with the thin 1/8 inch high density black vinyl top foam glued down. From there on I do it like you using a wooden frame to stretch the top material ( I am alone) which I glue to the foam. After I tack the material down and trim it I use a non hardening black sealer under the metal tack strip to seal out the water then insert the rubber seal. When done it's not any thicker than a stock top insert. I started doing it this way because it allows me to put Dynamat on the roof for a little more sound deadening.
    Standard32, pprather and Algoma56 like this.
  18. Standard32
    Standard32
    from LA
    That's really smart to be able to dynamat it...I bet that does help. I thought about sealer, but kinda halfway hated to do anything yet in case I decided to paint my tack strip...I guess I fear commitment, ha! Obviously my car isn't a "finished" kinda car, but sealing it up would definitely be something I'd worry about if I had fresh upholstery... I bet a lot of guys ended up welding a roof insert in over the years because they were afraid of leaks.
    deathrowdave likes this.
  19. Ron Plumlee
    Ron Plumlee
    Question: did you have the original "tack strip" channel and wood to work with? 34 is different than 32, and nobody makes repro strip for 34....so I plan just make from thin waterproof ply or luan wood so I have something to staple to. Suggestions welcome.
  20. krylon32
    krylon32
    from Nebraska
    My tack strips have always been painted before I install them. I've had quite a number of deuces with top inserts and have never had a water leak to date.
  21. chinarus
    chinarus
    from Georgia
    Great video !
  22. Sweet ride, digging that cam'ed out small block too, come do my 36? :cool: Kudos.
  23. Saxon
    Saxon
    from MN
    Don't pull the fenders off that gem. If you like I can scan a ton of sic 32 fender cars from the littles. Or someone else can post some.
  24. aripo
    aripo
    from Finland
    Nice video!
  25. bobbooth
    bobbooth
    from limeyland
    Thanks for sharing your " how to" clip, Got to do the same on a 34,5w. Real cool coupe by the way,Great stuff
  26. JimmyD3234
    JimmyD3234
    from PA
    Nice Job Thanks For Pics Love The Car Is It For Sale :cool: :cool:
  27. KEEPITMOSTLYSTOCK
    KEEPITMOSTLYSTOCK
    Hi I've watched your videos, great job,
    I actually am in the market for a Henry 32. I love your car, you have well seasoned taste for a young guy. I'm in BC so I would like to find something closer. You're not in California by chance?
  28. Tim
    Tim
    from KCMO
    Sure is
    Louisiana ;)
    Killer car, can’t believe he’s letting it go.
  29. Smoke4570
    Smoke4570
    Really like the video. Extremely informative. BTW, love your car too!
    Sent from my SM-G950U using The H.A.M.B. mobile app
  30. 19Eddy30
    19Eddy30
    from VA
    Does this Video still exist or play ? It say must have permission from owner , I pm Standard32 about 4 days ago, no response
    my2nd40 and kidcampbell71 like this.
