Customs finishing off my 38 chevee project
Discussion in 'The Hokey Ass Message Board' started by nunattax, Aug 31, 2015.
Tags:
  1. Leakie
    Leakie
    Now you will know how to do it on the next build. :)
    nunattax likes this.
  2. nunattax
    nunattax
    from IRELAND
    this is only the prototype Leakie ill make those revisions for the production model.
    Leakie likes this.
  3. nunattax
    nunattax
    from IRELAND
    shim pack 3 002.JPG moved on to aligning the front end .aiming for 4 degrees negative castor 0 degrees camber 1/8 total toe front.drilled and wired the shim pack used ARP bolts and locknuts.got my own stainless shims cut id recommend many thin shims over less rigid thicker shims will conform much easier
  4. Leakie
    Leakie
    More importantly, what was in the shot glass?
  5. nunattax
    nunattax
    from IRELAND
    tablets every fucking day,but occasionally a wee drop of JIM .
    Leakie likes this.
  6. nunattax
    nunattax
    from IRELAND
    nice to learn something new especially when it works out .
    CAMBER= -1/2 degrees
    CASTOR= 4 degrees
    TOTAL TOE =1/8 in alignment finished 001.JPG
    tb33anda3rd likes this.
  7. nunattax
    nunattax
    from IRELAND
    rear could be done tomorrow
  8. nunattax
    nunattax
    from IRELAND
    rear nearly done need to sort out 2 shims
  9. nunattax
    nunattax
    from IRELAND
    filler cap stage 1 002.JPG filler cap stage 1 001.JPG moving on to the petrol filler cap situation.day 1 stage 1
    TFoch and tb33anda3rd like this.
  10. nunattax
    nunattax
    from IRELAND
    TANKS filler cap assembly sits too high ,need to shorten that a bit
  11. nunattax
    nunattax
    from IRELAND
    sanded the floorboards to seal the underside.kin hell almost six years since I varnished the top side .yesterdat I was painting the underside of the boards black,but now I spotted the date I will be varnishing it. routered the boards with numbers so I could replace them where I found them..once these boards are sealed and dry they will be bolted home.
    Leakie and tb33anda3rd like this.
  12. nunattax
    nunattax
    from IRELAND
    made a bracket to mount the twin horns.these things are loud ,get out of my way polish boardsetc 001.JPG polish boardsetc 002.JPG
    horns are vw golf so will probably be reliable
  13. nunattax
    nunattax
    from IRELAND
    n polish boardsetc 005.JPG polish boardsetc 007.JPG polish boardsetc 003.JPG polish boardsetc 006.JPG polish boardsetc 006.JPG sanded and stained the boards,had the filler neck shortened as well.,still some fine tuning there.
    PONTNAK123, TFoch and Leakie like this.
  14. nunattax
    nunattax
    from IRELAND
    START UP FIRST ATTEMPT 18-06-18 001.JPG START UP FIRST ATTEMPT 18-06-18 002.JPG made first attempt to fire her up today but no happy ending so far.no spark and no fuel pressure.seven years since the motor ran so some casualties expected.full 14 volts to the dizzy and fuel at the petrol pump.no spark,no fuel pressure.pump diaphragm is the suspect need tofault check the dizzy to mor.push it out into the sunshine,nothing caught fire,no fuses blown,no leaks ,good oil pressure on the starter only a matter of time before it runs,looking forward to hearing it run.sheetmetal is all painted and ready to go except the cills .lots easier to fault find without the wings in the way
    the cills straightened out ok ,bubba thanx
    j hansen, TFoch and tb33anda3rd like this.
  15. Chris good move getting it running and tuned in without having to hang over the fen'......i mean wings.
  16. nunattax
    nunattax
    from IRELAND
    well another day down.cleaned the holley fuel punp liberally sprayed wd 40.and scrope the rust from the one way valves.pump is putting out 6 PSI now,nearly bought another.Ciarain saved the day good job bud.
    no spark situation is still the same -no spark.tested the coil,not good .borrowed another hei in the hope of swapping out some parts but that was crocked as well.ill order parts this evening.nearly there.
  17. nunattax
    nunattax
    from IRELAND
    parts are ordered two days now slow to leave the depot..hope they will be on the way in the morning
  18. pila38
    pila38
    Cant wait to hear it runnin!
  19. nunattax
    nunattax
    from IRELAND
    its been a long time coming
  20. bubba55
    bubba55
    Glad the door cills / rocker panels worked out for ya Chris - Looking good me friend - keep at it
    I'm still working on me A - about got the chassis done - then on to da body -
    later you Irish NUT !
  21. nunattax
    nunattax
    from IRELAND
    lets see the A SHOW IT OFF.id love one but the c5 would have to go first to finance it.
  22. nunattax
    nunattax
    from IRELAND
    big day today 4 july distributor parts arrived from summit took 12 days to arrive .rotor,cap and coil,plus module .fired right up great to hear it running again.fuck its loud.its not running right.stripped out the carb .its full of crud.major rebuild kit needed new gaskets anyway and a few new jets..idle mixtures need to be dialled in and timing set.
    ive a set of comp cams roller tipprd rockers to fit as well.
    it was very hot today 31 c so we hot wired the spal fan.sparks due on Friday to do a shift.
    wire the fan up correctly is top of the list
    good to be making progress.many thanx to ciarain for getting it running top job.
    Leakie, pila38 and tb33anda3rd like this.
  23. pila38
    pila38
  24. nunattax
    nunattax
    from IRELAND
    yeah I will do,i think I can finish it
  25. nunattax
    nunattax
    from IRELAND
    bas the sparks arrived today we wired the fan and maxi fuse plus ran the wires forward to the lights /indicators and horns.theres a bit for me to do before he arrives back again.we will be tackling the dash the next day.spal fan ready to rock.
    made a start on fitting the new rockers,do some more tomorrow hopefully
  26. nunattax
    nunattax
    from IRELAND
    fitted the roller tipped rockers,whats next on the list,long list
  27. pila38
    pila38
    Cross one thing off the list, add three more. I know the process well.
  28. nunattax
    nunattax
    from IRELAND
    THATS ABOUT THE SIZE OF IT.
  29. nunattax
    nunattax
    from IRELAND
    ordered the demon rebuild kit from summit on mon 2 days on nothing much happening according to the tracking.if we had the kit were confident we ll have it running well.its firing up easy and idling well.spal fan didn't cut in on the thermostat like I expected it to..yet.
    however the first small spin,up/dowh the road isn't too far off.
  30. nunattax
    nunattax
    from IRELAND
    significant day today after over 7 years we got it running acceptably and it moved under its own steam..felt good to be driving at long last.went around the block and back over the pit.
    leaking power steering fluid---fixed that one
    leaking water from lower rad hose at the rad---fixed that one with hjgh quality clamp,tightened with 1/4 drive ratchet
    leak at the sacrificial anode ----removed it re taped it tightened it up.another snag sorted
    issue with the thermostat on the spal fan.its coming on early and staying on.not resolved yet waiting for a call from the sparks.
    first job tomorrow is inspect the thermostat and drill a 1/8 hole in it,or clean or replace depending on condition.,find a keyring for the spare key before it goes west.
    feels good to be nearly back on the road.
    need to write another to do list
    theres plenty to put on it.
    some of the neighbours hadn't seen it before liked the look and loved the rumble off it.and no its not a rat rod and yes I do have the drivers door
    TFoch, Leakie and tb33anda3rd like this.
