Technical 35 ford floors .
Discussion in 'The Hokey Ass Message Board' started by Gurt74, May 27, 2018.
  1. Gurt74
    Gurt74
    So, im tearing into this 35 coupe after having the shell blasted and primed, so i know exactly where the rot is. Got patch/repair panels and a complete floor from ems. Patch panels seem pretty good. Then i started laying out the floor panels. The original floor looks like its wrapped over the chassis, down the sides then picks up on the body mounts etc. The ems floor wont be wide enough to do that . Do you guys just weld the floor to the body or mount the floor to the chassis then attach the body to the chassis? I was going to do the body repairs then brace and lift the shell off the chassis ? Sorry if these sound like dumb questions but i gotta get this right. Im guessing there probably isnt a right or a wrong way, but you guys have done this loads more times than i. Pics for attention as i probably havnt explained myself very well. 20180527_134335.jpg 20180527_134316.jpg 20180527_134305.jpg 20180527_134254.jpg
    Sent from my LG-K520 using The H.A.M.B. mobile app
    reagen likes this.
  2. trey32
    trey32
    What your talking about over the sides are subrail.
    Need to get a new set of subrails, they'll complete the equation.
  3. Gurt74
    Gurt74
    I have the rocker panels. So are you saying there's another panel that attaches to the end of the rocker panel in behind the b post ?
    Sent from my SM-A520F using The H.A.M.B. mobile app
  4. trey32
    trey32
  5. uncle buck
    uncle buck
  6. Gurt74
    Gurt74
  7. uncle buck
    uncle buck
    Those will connect the a pillar to the b pillar fine with a little work. You still need the rest of the rockers though. Both McPherson Auto in Kansas and I believe Roadster Ute in Orange or Anaheim California use to make them but I’m not sure if they still do. You may be able to modify some Drake or Carpenter 40 Ford ones too. These are what tie the floor and outer sheet metal together and where it all bolts to the frame
    Gurt74 likes this.
  8. Gurt74
    Gurt74
    That's great info ,thank you. Do you have a web link please as I'm struggling to find one. Plenty of rockers but no sub rails.
  9. southcross2631
    southcross2631
    What transmission are you running ? I did a 35 for a customer and had a C-4 and had buggered up floor pans. Converted to an AOD and had to make a bigger tunnel.
  10. Gurt74
    Gurt74
    Can't find them on Bob drake or Dennis carpenter :(
  11. Gurt74
    Gurt74
    Drawn a blank so far. I'm just wondering if it's just a plain z shape, across the floor down the side of the chassis then connects to the bottom of the b post ?
    Anyone got a pic please, may help me folding a new panel.
  12. mrquickwhip
    mrquickwhip
    On a side note. Are you sure the lower rear quarter repair panels are correct? They look short to me. The ones I got curled just round the b pillar and welded in where the door closes.
  13. Gurt74
    Gurt74
    Hi Bob. Yes I've cut it short because I've got to do a repair on the door pillar and didn't want to lose the belt line reference. 20180528_160022.jpg
  14. uncle buck
    uncle buck
    lothiandon1940 and Gurt74 like this.
  15. Gurt74
    Gurt74
    lothiandon1940 likes this.
  16. Maybe this will help.
  17. Gurt74
    Gurt74
    Thanks Abone,that helps a lot.
  18. Richard Head
    Richard Head
  19. lewk
    lewk
    from Mt
    Shoot, I’m 6 months late on this one. I’m doing things the hard way with mostly Ford tin. I separated the body from the floor and subrails on my ‘35 3 window and rebuilt both. Pics:
    Hopefully this is helpful if you’re not already done with your floor/subrail project. There are probably more pics in my build thread for my coupe.
    Gurt74 and lothiandon1940 like this.
