Technical Anybody Got One of them Garage Car Lifts ?
Discussion in 'The Hokey Ass Message Board' started by bondolero, Jul 13, 2017.
  1. Willys 36- a single post lift is very traditional!
  2. 5window
    5window
    A used car lift is just that-used. Possibly very well used. Do you want to get under a very well used lift with a car under it? Plus you could spend more getting the lift action repaired than a new one would cost. I would suggest having any used lift full checked out by a qualified technician before you purchased it.
    jeffd1988 likes this.
  3. HotrodHR
    HotrodHR
    Buy a 4 post... best purchase I've made in years. Should have done it sooner!
    Beats crawling around on a hard floor!
    bondolero and TagMan like this.
  4. fordflambe
    fordflambe
    I've owned three over the years, both 4-post and 2-post. Each has distinct advantages and disadvantages. You can see more about this in the thread mentioned above. Regardless of which you end up with, I like to tell those that have never owned one, to be careful and respect it for what it is. One of the local car enthusiast in my area got aggressive working under one of his cars and shook it off of the lift. He never made it out from under the car in time.................They are wonderful tools when used properly but can be very dangerous if not.
    jeffd1988 and bondolero like this.
  5. classiccarjack
    classiccarjack
    I love my lift, I can't live without it! If I work off the ground, I kinda want to keep lying there.... LOL
    Sent from my XT1585 using The H.A.M.B. mobile app
  6. classiccarjack
    classiccarjack
    I forgotten to mention... 2 Post, 10,500 pound rating, an extra 13"wide to clear my 1992 Dodge D350 towing package mirrors.
    bondolero likes this.
  7. Phil1934
    Phil1934
    If not planning on stacking cars, could you just position posts between trusses like this web pic? [​IMG]
  8. MrMike
    MrMike
    Do a search on the Garage Journal, this question comes up all the time and is usually not as complicated as people think.
  9. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    Just finished the installation of a Bend Pak HD-7P Tuesday. It had features I liked and was in my price range. It was also sized to fit in the space I had. It is a 7000 lb high lift which will work for stacking cars. I have a 12.6 ft ceiling. I bought it from and had it installed by a reputable lift company out of Omaha and glad I did. Not sure what the opinion of Bend Pak is on here (I know it's foreign made) but the local trade school has some and they seem to work good for them.
  10. lonejacklarry
    lonejacklarry
    Thanks, I'll look there.
  11. Blake 27
    Blake 27
    My buddy's outdoor lift on which he built a roof. DSC08762-001.JPG When it's all the way down, the roof laps over the gutter on his shop.
    olscrounger, jeffd1988 and TagMan like this.
  12. jeffd1988
    jeffd1988
    This one is bitchen. Love this right here. Even tho it will be nice to be inside. But hek that roof tops it. Excellent
    Sent from my Z981 using The H.A.M.B. mobile app
    reagen likes this.
  13. Kan Kustom
    Kan Kustom
    Nice 40
  14. fiftyv8
    fiftyv8
    from CO & WA
    My buddy purchased a 4 post hoist from some company in AZ which when not in use it drops down onto some wheel gizmo's and can be moved out of the way.
    I always thought that would be a good outside unit that can also be moved inside when required or make a drive in bay clear.
  15. loose49
    loose49
    from tucson az
    Gilbert is not that far from Tucson I purchased a kwik-lift July of 2016. It had not been delivered yet and I had emergency back surgery . Then a second surgery early 17. It goes up about 18 in. Red powder coated never used payed $1549.oo . Would sell for $1000.oo will fit in back of a pickup Mark if you want to call 520 321 4635 thanks
  16. loose49
    loose49
    from tucson az
    Gilbert is not that far from Tucson .Bought a new Kwik-lift 7-1-16 had back surgery before it got here , and another back surgery after it got here. Never put it together. Paid $1500.oo for it. would sell for $1000.oo Will fit in the back of a long bed p/u Mark if it's eaiser to call try 520 321 4635 Thanks
  17. Sheep Dip
    Sheep Dip
    from Central Ca
    Thanks Kan Kustom
  18. Early Ironman
    Early Ironman
    Another great thing about the Maxjax.
    You can position it in the front and rear to lift the car. Giving full access to the sides for back pain free block sanding for example. IMG_5446.JPG
    Chavezk21 likes this.
  19. petew
    petew
    from Mebane, NC
  20. petew
    petew
    from Mebane, NC
    The 51 Ford is sitting on a Ranger Quickjack . Completely portable for use inside or out.
    I use it for brake jobs or just to put the car at a better height for cleaning.
    tofords likes this.
  21. Oilguy
    Oilguy
    Please don't laugh at my ignorance but what is a boogie board? Seriously. Sounds like something I could use.
  22. 51504bat
    51504bat
    Boogie board, belly board, surf rider. All the same. Styrofoam flotation device used to surf the waves on your belly. Some have a hard plastic covering but I use the ones without any covering, easier on the knees. Some guys use kick boards since they're smaller but usually are made of a harder material. IMG_3766.JPG IMG_3767.JPG
    Oilguy likes this.
  23. Bought a Rotary Evolution lift. Had it about 8 years.
    Wish I’d bought a second now that I’m 71 years old and not inclined to ride horizontal on a creeper any IMG_2731.JPG IMG_1718.JPG longer.
    It’s great for stacking cars and an answer to making work a whole lot easier.
  24. okiedokie
    okiedokie
    from Ok
    Yes indeed.
  25. ramblin dan
    ramblin dan
    Went with a direct lift. Had to have the garage door rails brought to as high as they could go and had a lift master side motor installed. Have a low ceiling, hence the lo boy. IMG_1446.JPG
  26. Craig Owens
    Craig Owens
    I did the same thing...built a car port-type roof over my lift and welded it to the lift so it goes up and down with the lift. The area I have available is so limited, it was about the only solution I could think of to provide a somewhat sheltered parking place for another car since all my garage space is spoken for. It works great. Car Port 4-13-18 003.JPG Car Port 4-13-18 001.JPG Car Port 4-13-18 007.JPG Car Port 4-14-18 002.JPG Car Port 4-14-18 003.JPG
  27. Oilguy
    Oilguy
    Thank you.
  28. Joy Liu
    Joy Liu
  29. rlsteel
    rlsteel
    If you buy a 4 post, remember to protect the lower car if the upper car has any kind of leak. my tip for today RLS
    stillrunners likes this.
  30. 57JoeFoMoPar
    57JoeFoMoPar
    Yup. It's life-changing. Seriously, after I bought it and worked with it for a while, I got to thinking about all of the other dumb shit I spent the same (or more) amount of money on and felt like a total buffoon for not doing it sooner.
    Foe example, in this picture, I was replacing all of the gaskets on my rear axle and the pinion seal, and replacing a pair of universal joints. This was a clean and no-nonsense job with the proper equipment that I was able to quickly move through in a couple evenings of work. This would have been a pain in the ass crawling around on the ground like an animal.
    rod1, ekimneirbo and Jeff Norwell like this.
