just need input from guys that have done it , whats the best 5 lug rearend to use im converting from 4 lug to 5 lug , ive heard that the 87 ford ranger is the way to go then ive heard go with the tried and true 8 inch ,,,,, im going to run astro supremes in 14x6 w/ 2.75 back spacing so i think i want a 56 inch rearend ,,,,,,,,,,any help would be great thanks guys
Have you looked into having your axles and drums redrilled for 5 lug or buying 5 lug replacement axles and drums? Heck of a lot easier than swapping rear ends. Just a thought.
Unless the rear is from a 4 liter ranger they are 7.8 and not real strong. Ok if you aren't putting to much power on it. Also one axel is shorter, the right one I belive and it offsets the center of the diff. which is fine becuse you want your u joints to work. The 8.8 is good and strong as they used them in most f150's 80's to 90's and in alot of other rwd ford stuff.
The 4 lug and 5 lug rears in the Falcon are completely different. that little wimpy 4 lug rear in a 62 Falcon is great in stock form, but would be hard to adapt, and nothing from the 8 inch will fit. The best one to get is the original 5 lug Falcon rear from 63-65, then the Maverick. On a good day I can get $300 for a Falcon one, and the Mavericks go for about $200. Pretty cheap for a nice upgrade.
The Maverick 8" wil go right in with no problem, but you are going to need new U-bolts and different lower shock plates.(grab the Maverick plates) The Mav rear will also have beefier axles, and a ribbed centrsection. The Granada 8" will also work, but it is app, 1" wider.
thanks you guys , im trying to find a rearend that can handle 200hp my budy has a line on a 91 ranger 8.8 so im hoping that works out i also need it to be geared close to a 2.73
do any of you guys know anyone selling on of these rearends in socal ,, im having a hell of a time i need rearend to be 56 inch to 56 1/2 wide thanks guys any help rocks
I'm a ways away but I have a 63 Sprint 8" with automatic gears sitting here... Sent from my SM-G900V using The H.A.M.B. mobile app
Again, old thread, but Ford Ranger 8.8, from 1983-1992, is 56-1/2" wide. I have one under my '60 Falcon. They can be had with 9" or 10" drums. The pinion is slightly offset, so you will need a small diameter driveshaft to use the stock floor.
I don't have a stock floor. I have a handmade tunnel that is built to accept a 1960 Thunderbird console, clear a T56 6-speed, and tuck the exhaust. You could have the stock one modified.
