Technical Crab dizzy onto a 39 engine.
Discussion in 'The Hokey Ass Message Board' started by aussie57wag, May 21, 2018.
  1. aussie57wag
    aussie57wag
    from australia
    I have a stock (for now) 39 tudor. I want to ditch the stock distributor for the later crab type. As the 39 style coils just are not available. The car is 6 volt and I have the opportunity to buy the harmon and colins 6 volt one pictured one. I understand there is an adapter available to make it fit. Does anyone know where to get one? FB_IMG_1526809330715.jpg
    Sent from my SM-T805Y using The H.A.M.B. mobile app
  2. tub1
    tub1
    from tasmania
    a chap up in Sydney makes just what you need ive bought from him at Bendigo a great guy he is the guy that cast the 34 heads cant remember his name atm
  3. aussie57wag
    aussie57wag
    from australia
    Sounds like I need him. Ask around. See if you can find out his contact. Thanks.
  4. Jim Kerr?
  5. Mac VP
    Mac VP
    We stock both types adapters if your buddy doesn’t have them. Assuming you have the 3 bolt timing cover, and the stock 39 camshaft, this is the adapter. It will move the distributor out front by an extra 3/8”. If your motor has the shorter 42-48 camshaft, you’ll also need the spacer button.
    http://www.vanpeltsales.com/FH_web/igntn-partsprices-pg1.htm
    48fordnut, bct and X38 like this.
  6. wheeldog57
    wheeldog57
    You can also run a coil adapter like this. Readily available and cheap too KIMG0298.JPG
    aussie57wag and bct like this.
  7. thommoina33
    thommoina33
    Alliance Member
    from australia
    Yes, Jim Kerr.
  8. tub1
    tub1
    from tasmania
    sounds like you blokes know the man , I used one of his adapters on a 37 motor worked just great , unlike one I bought from another chap in another state
    aussie57wag likes this.
  9. aussie57wag
    aussie57wag
    from australia
    Thanks. If I cant get one in Australia I will follow this up.
  10. aussie57wag
    aussie57wag
    from australia
  11. aussie57wag
    aussie57wag
    from australia
    How do I contact him?
  12. aussie57wag
    aussie57wag
    from australia
  13. On the Harmon & Collins dizzy, make sure that the middle spacer (orange part) and the rotor are good. Those parts are difficult to find.
  14. Early Ford V8 Club, NSW. They have a website and I think he's an office bearer.
