Technical Model T axle modification for lowering...
Discussion in 'The Hokey Ass Message Board' started by ratamahata, Apr 7, 2018.
  1. Hey guys... A friend of mine ask about if I saw over The Hamb a modification like the picture below... for lowering a model T banger...
    That the plans for his build!! The idea!!
    Sent from my SM-G610M using The H.A.M.B. mobile app
  2. The37Kid
    The37Kid
    Does he plan to do a traditional drop or fab that and do a lot of welding? Either way it looks too drastic. Bob
  3. Welding
  4. bct
    bct
  5. manyolcars
    manyolcars
    I hope hes not cutting off the ends and bolting them back on!!
  6. Completely bolt on... Made of a solid bar... Ok may be my Friend is a little anxious with this build!
    Not finish right now!
    Have my questions about the successful of this design...
  7. bct
    bct
    how does he plan to test it?
  8. Phil P
    Phil P
    That drop puts a lot of leverage on the stock parts. It might be ok for a parade car but hitting a pothole at any speed would concern me.
  9. doyoulikesleds
    doyoulikesleds
  10. Okie Pete
    Okie Pete
    WOW that is thinking out of the box. Not sure how safe it is but wow.
  11. flatheadpete
    flatheadpete
    from Burton, MI
    Glad I'll never be on the same roads as that. That looks Friday the 13th scary.
    Hollywood-East and The37Kid like this.
  12. treb11
    treb11
    Somewhere on here is a thread about building a Model T dropped axle from two axles. Or have Sids drop it. Either way, leave that half ass fabricated crap for garden carts.
    Sent from my SM-G950U using The H.A.M.B. mobile app
    The37Kid and Atwater Mike like this.
  13. 117harv
    117harv
    I wouldn't do it, I think this is a better option. 188265.jpg dropped axle2.JPG reverseye.jpg
    Hollywood-East likes this.
  14. dumprat
    dumprat
    from b.c.
    Somewhere lost in the HAMB is a thread on dropping a T axle 1920's style. They used a set of brackets that located the spring behind the perch with a significant drop. Maybe an internet search is in order.
    I believe the Frontenac cars had these bronze brackets.
  15. rusty valley
    rusty valley
    buy one from okie joe then your done
    GASSERBOB and Atwater Mike like this.
  16. With that much hokey drop on that axle , I would be worried that the end would break off or the spindly wishbone would bend. Either one causing a bad incident and maybe ruining peoples day for a long time. I would just have SID drop your axle and beef up the wishbone, safest bet. Mitch
    Atwater Mike likes this.
  17. Atwater Mike
    Atwater Mike
    Call Sid. Period.
    gimpyshotrods likes this.
  18. The37Kid
    The37Kid
    ROOF Made them, I used an original pair to have a new set cast. think Snyder's sells repos now. Bob
  19. Many thanks for the replies, my friend was advised... Tomorrow he planned to take a ride for testing... He made it some lowering brackets or support for the rear...
    I[​IMG][​IMG]
    bct likes this.
  20. A92B4A14-B60C-40F6-BD54-DFC65E437979.jpeg You could use a lowering bracket , I have this one that’s extra from a project that I would sell
  21. gimpyshotrods
    gimpyshotrods
  22. fiftyv8
    fiftyv8
    from CO & WA
    I must ask WHY would you bother, when there are so many other tried and proven solutions out there for lowering...
    The37Kid likes this.
  23. I'm surprised no one has mentioned '27 spindles. They are 1" lower than previous year T spindles. I used a 3" dropped axle, reversed eye spring, and '27 spindles to lower my speedster 5" in front.
    ratamahata, alchemy and The37Kid like this.
  24. Commodoreswab
    Commodoreswab
    from West TN
    Chevy spindles offer more of a drop than later ford. On mine I fabricated brackets similar to the laurel pictured. Rather than relocating the perch, a rear perch is mounted into the bracket. I don't have a clear picture of mine right now but this will give you an idea. I have 27 spindles and a late spring so I could lower it more just by using some chevy spindles and an inverted eye if I want. Of course I could also still swap out the axle for more if needed but feel I am about "right" on the other side I could go earlier spring ot earlier spindles to bring it up.
