Technical Erson Cam i.d
Discussion in 'The Hokey Ass Message Board' started by 9sectruck, Apr 3, 2018.
  1. 9sectruck
    9sectruck
    Can anyone help I.d this cam for me? I just picked up a 327 chevy.
    The cam has Erson Viking 100M on the end and 1030 stamped just below.
    Anyone have some old Erson catalogs.
    Thanks.
    Sent from my SM-T550 using The H.A.M.B. mobile app
  2. 9sectruck
    9sectruck
  3. 9sectruck likes this.
  4. Atwater Mike
    Atwater Mike
    They ARE good about researching old info. My son has lots of early Sig Erson products, they've replied to every question.
    Howard's Cams' son is also responsive, dug for some old info for me.
  5. 9sectruck
    9sectruck
    Thanks for the replies, I've sent an enquiry off to them.
    Will let you know how I get on.
  6. 9sectruck
    9sectruck
    Great service from pbm , came back with the cam card specs the same day.
    Thanks for the link.
    bigmikes50chevy likes this.
  7. 56sedandelivery
    56sedandelivery
    So..................what was it? I have an old NOS Erson cam, and it's hardly anything more than a stock Chevrolet cam.
    I am Butch/56sedandelivery.
  8. 9sectruck
    9sectruck
    Pt.#. E111081.
    Solid lifter.
    115' lobe separation.
    Valve lift : .440" in. .440" ex.
    Duration: 310 in. 310 ex.
    @.050" 244 in. 244 ex.
    Not sure what that equates to rpm range, cam specs not my strong point.
    Hope it's going to work, the motor had an early Torker fitted to it and would like to keep the same parts.
    chevy57dude likes this.
  9. That is similar to the old 327/350 hp cam. It was .447 lift, hyd.
    Yours has a little less lift and a little more duration.
  10. 9sectruck
    9sectruck
    Thats cool,seems like it was a reasonable choice for this motor then. Not sure about the Torker intake though, not much off idle they operate 2500/6500 rpm. May go for a dual plane instead.
  11. Deuces
    Deuces
    Should sound great!!!.... :)
    chevy57dude and 9sectruck like this.
  12. Deuces
    Deuces
    Something similar to the 67-72 Z/28 intake should do the trick...
