Having run into a strange project i could need some cam related info and help from someone with a big Offy 220-255-270, or cam experts with related experience. Is there such a thing as a offy cam go to guy? Thanks!
Ed Winfield was the go-to guy, he was consulting on Offy cams even into the 1970’s but obviously that won’t help. What info are you looking for, is it camshaft specs, assembly procedures, or?
Need to know all the diameter dimentions on the cams, center to center on lobes and bearings, standard follower diameter. Could also use some different sober cam specs for gasoline use.
Contact Shnider cams they made my 270 cams he has been making Offy cams since the late '50's or Stewart Van Dyne he is Mr Offy. http://www.vandyneengineering.com/
