Projects FED with killer Flathead
Discussion in 'The Hokey Ass Message Board' started by fenderless, Nov 16, 2010.
  1. mikebishop37
    mikebishop37
    Nicely done, Mark!
    Model A Mark and fenderless like this.
  2. fenderless
    fenderless
    from Norway
    What rods are going to be used on that beautiful crank Mike? :) My Moldex had to be rebalaced after I had to change the rods, Not so purdy anymore ;)
  3. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Thanks Mike
  4. fenderless
    fenderless
    from Norway
    As a part of the updates on this engine, I desided to change the timing gears to early style for thrusting towards the block. As Bored&stroked adviced, I bored å small Hole up in the Main oil feed to improve lubrication betveen the cam and block face.
    Model A Mark and loudbang like this.
  5. fenderless
    fenderless
    from Norway
    On the last race I managed to break one of the Main caps in the rear end, the Chrysler 8 3/4" could not handle the power from the mighty Flathead ;-) With two New MW mains it should hold, I Hope :-D
    Jet96, Model A Mark and loudbang like this.
  6. fenderless
    fenderless
    from Norway
    Have made some progress in these Easter days :-D Just had to mock it up With the New magneto, to see how it fit. One thing for sure, it looks massive DSC_0995.JPG DSC_0994.JPG
    Jet96 and loudbang like this.
  7. Model A Mark
    Model A Mark
    from dallas
    1. Holley 94 Group
    Looks great, that mag ortta make a spark ...
    loudbang and fenderless like this.
  8. fenderless
    fenderless
    from Norway
    As most internals are in place, and With a new box of stuff from the US, it's time to do some external stuff. All the New port nozzles are taped and in place, and New hoses are ready to be pressed. The New AFR logger also arrived DSC_1069.JPG
  9. fenderless
    fenderless
    from Norway
    Latest report. After useing a copper intake gasket With silicone, I was fed up cleaning the surface when we lift the intake off. I have been pondering how to make a new gasket, that seal well and that can be reused without use of liquid sealant. So I desided to use a dur aluminium base 0,7 mm thick, gluing 0,5 mm viton rubber on both sides making a sandwich. Here is the result, Hope it will work B-) DSC_1084.JPG DSC_1081.JPG
  10. fenderless
    fenderless
    from Norway
    Slow progress, but With some smal nicks and nucks the New engine will soon end up in the chassis!
  11. 392
    392
    Looks bad ass and should run the same. Great job.
  12. fenderless
    fenderless
    from Norway
    Thanks, hope it will ;)
    KBS
  13. fenderless
    fenderless
    from Norway
    Finally got some done this weekend, the new engine is back in the chassis. Some minor work on wiring of the new boxes and it should be ready to be fired in a week or two ;)
    loudbang, chryslerfan55 and Jet96 like this.
