Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. 340HilbornDuster
    340HilbornDuster
    patmanta, Bam.inc, Stogy and 2 others like this.
  2. 340HilbornDuster
    340HilbornDuster
    Stogy, AndersF, Dannerr and 1 other person like this.
  3. 340HilbornDuster
    340HilbornDuster
    Motors been sitting there for a couple years... glad I remember the oil pump / pickup.
    No room for those fancy white boards w. Stuff to do list...[​IMG]
    Sent from my SM-G930T using The H.A.M.B. mobile app
  4. 340HilbornDuster
    340HilbornDuster
    Gas-O-lene lines.
    Dang, Bolts Metric....! Buy new ones tomorrow...ALSO -
    Need fan belts, radiator hoses, bolts, coolant, DOT-3, black tape, 10-30w, alcohol free GAS, bolts (shocks) (mount) , brn wrinkle paint, make shift door locks (slide), post office.
    Sorry made it my shopping list....[​IMG][​IMG]
    loudbang, patmanta and AndersF like this.
  5. 340HilbornDuster
    340HilbornDuster
    Don't have the tool to get those races off.
    Was going to be lazy and drive it to the show on Saturday but then I'll probably ruin the bearings...
    Maybe I'll throw the sucker in the oven.
    COE - 400F
    Aluminum 2.73 - steel 1.63....
    Next project - while It's baking.[​IMG]
    Sent from my SM-G930V using The H.A.M.B. mobile app
    loudbang, AndersF and Dannerr like this.
  6. 340HilbornDuster
    340HilbornDuster
    That was FUN...
    Baked @ 275 30min.
    Still a &!+(# without a press..........[​IMG][​IMG][​IMG]
  7. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    I use my build thread for a to-do list quite often.
    Hey, where did you get that wire loom? It looks GREAT!
  8. 340HilbornDuster
    340HilbornDuster
    BRAIDED EXPANDABLE SLEEVING RATTLESNAKE
    TECHFLEX
    (on e-bay...)
    loudbang, AndersF and patmanta like this.
  9. 340HilbornDuster
    340HilbornDuster
  10. 340HilbornDuster
    340HilbornDuster
    If you like good brakes, and you don't like that new Billet stuff.
    There's few better-looking calipers than these...[​IMG][​IMG]
    '52 F-3, AndersF and loudbang like this.
  11. 340HilbornDuster
    340HilbornDuster
    Pressure regulator plumbed.....nah...
    Manifold hose smashed / cut somehow...
    [​IMG][​IMG]
    Stogy, AndersF and loudbang like this.
  12. 340HilbornDuster
    340HilbornDuster
    OahuEli, Stogy, AndersF and 1 other person like this.
  13. 340HilbornDuster
    340HilbornDuster
    Stogy, biggeorge, AndersF and 3 others like this.
  14. 340HilbornDuster
    340HilbornDuster
    Not going to the show tonight.
    Well I am......not the tub.
    Not going to rush it now...
    would be great to show up in a bonfire..
    45 PSI fuel ...!
    + 80 bucks for 6 feet on AN6!!
    GAS PEDAL.
    Bleed brake system.
    Cotter pin / torque all joints.
    FILL ALL FLUIDS...
    Check gaskets first.
    O2 sensor (gotta find a spot in the.
    "Exhaust system."..)
    KILL SWITCH!
    But it's close![​IMG][​IMG]
  15. 340HilbornDuster
    340HilbornDuster
    Stogy and loudbang like this.
  16. 340HilbornDuster
    340HilbornDuster
    I'm Lucky! / Stupid (it was raining outside!..)
    Hanging the "conduit" B4 I took the opener down . Noticed the plastic plugs fell apart...the opener plastic seems kinda brittle too....wonder what caused that.
    Windshield?
    Still got the pieces I chopped out. Easy peasy...[​IMG][​IMG]
    Stogy likes this.
  17. 340HilbornDuster
    340HilbornDuster
    Oh MISSED THE HILBORN!!!
    TINY SCRATCH ON THE RADEATER...
    I AM LUCKY!
    OahuEli, AndersF, Stogy and 4 others like this.
  18. Outback
    Outback
    from NE Vic
    Wow^^^ it's like it was guided past the Hilborn!
  19. 340HilbornDuster
    340HilbornDuster
    I know.....!
    Plastic coupler gone....
    Dunno What's up with da Plastic?
  20. 340HilbornDuster
    340HilbornDuster
  21. 340HilbornDuster
    340HilbornDuster
  22. 340HilbornDuster
    340HilbornDuster
    Doing something I'm good at...
    sitting down, staring at my car.
    A lot of times, if it looks right, it works right...................?
    Paralell Just LOOKS right....[​IMG][​IMG]
  23. 340HilbornDuster
    340HilbornDuster
    OT but still kinda project related....
    Did some research on Plastic Failure...
    I'M THINKING WELDING IS THE CULPRIT...
    Factors That Cause Failure
    A variety of factors both inside and outside of the molding process can impact the quality of a plastic part. Assuming that there are no issues with design, the root cause of plastic part failure usually lies in one or more of the following areas:
    Depending on the stage and conditions at which a problem occurred, the following types of part failures are possible:
    Mechanical failures are caused by an applied external force such as tension, compression, or impact. If these forces exceed the yield strength of a material, the part can deform, crack or break into pieces.
    Thermo failures occur when parts are exposed to extreme temperatures. Too high a temperature can warp, twist, melt, or burn the materials. At low temperatures, plastic becomes brittle.
    Chemical failures occur when chemicals causes the plastic to break down. Elevated temperatures, existing stress, or mechanical load on the part will amplify the effect of chemical exposure.
    Environmental failures are caused by factors such as humidity, ozone, ultraviolet light radiation, and pollution. The effects can vary from a change in color or a slight crazing or cracking to a more severe breakdown of the polymer structure.
    ----------------other site----------------
    During machining and processing of metal materials by means of welding and allied processes, gaseous and particulate hazardous substances are formed. Ozone is one of the important gaseous hazardous substances. Ozone (O3) is formed by ultraviolet radiation from the oxygen in air.
    AndersF likes this.
  24. 340HilbornDuster
    340HilbornDuster
    Henry made the holes already....
    Might cut them out and move down...?
    1. Hi/Lo, turn R, fogs.
    2. Hi/Lo, turn L, horn.
    Twist 1, Twist 2, 4 Bolts...
    All that stuff comes right off.
    [​IMG][​IMG][​IMG]
  25. 340HilbornDuster
    340HilbornDuster
    Sometimes it's good to slow down.
    So stoked about Henry's puka.
    I almost
    1. cut it move it down & Welded
    2. Step drill and fancy meassure...
    3. Think I'll borrow a hydraulic hole punch from the electric boys at work.
    [​IMG][​IMG]
  26. 340HilbornDuster
    340HilbornDuster
    Paint stripped that ugly green off.
    "Military grade" under it.
    Cut the flange off in the lathe on one.[​IMG]
    OahuEli, Dannerr, Stogy and 2 others like this.
  27. 340HilbornDuster
    340HilbornDuster
    Main power breaker bracket...
    Tricky piece to mount!
    First time it was upside down...!
    Had to cut it an re weld it...
    loudbang, AndersF and Stogy like this.
  28. 340HilbornDuster
    340HilbornDuster
  29. 340HilbornDuster
    340HilbornDuster
  30. 340HilbornDuster
    340HilbornDuster
    Dannerr, Stogy, OahuEli and 3 others like this.
