  1. swi66
    swi66
  2. swi66
    swi66
  3. jnaki
    jnaki
    upload_2018-2-27_4-53-43.png 1959 upload_2018-2-27_4-54-16.png 1959 Lions Dragstrip
    upload_2018-2-27_4-56-21.png upload_2018-2-27_4-56-33.png APRIL 1959
    Hello,
    This FED is one of the wildest early racers that we saw in person at Lions Dragstrip and Riverside Raceway in So Cal back in 1959-60. Looking at the race car, it looks simple enough, aluminum body, yellow tubular frame, Hemi motor. But, the first thing anyone notices is the huge centrifugal supercharger. It looks like it was taken from an aircraft motor and adapted for drag racing use. While most of the other race cars used Potvin styled 671 superchargers or the 671 on top, or plain Hilborn Injectors, this one was a big centrifugal blower sucking in air in front of the motor.
    This yellow FED was owned by Steve Pick and Joe Koenig out of Long Beach, CA. It was a regular attraction at Lions during those early days. It was an experimental idea in play as the suspension created the uplift when accelerating. The idea was to shove the power from the motor back to the rear wheels by shifting weight without lifting the front wheels off of the ground. This car moved down the strip with the front end still high up in the air, but wheels firmly on the ground.
    Jnaki
    It was a “one of a kind” idea that did well in those days. Sometimes, the tremendous power from the Hemi motor did lift the wheels off of the ground. But, the weight transfer was already started and continued all the way down to the end.
    upload_2018-2-27_4-58-17.png upload_2018-2-27_4-58-26.png upload_2018-2-27_4-58-36.png
    upload_2018-2-27_4-59-30.png upload_2018-2-27_4-59-41.png upload_2018-2-27_5-0-58.png
    upload_2018-2-27_5-1-17.png 1960
  4. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
  5. keef59
    keef59
    Movie bus, Los Angeles 1931 tumblr_o409zwuRj91tcqhjho1_1280.jpg tumblr_o409zwuRj91tcqhjho4_1280.jpg tumblr_o409zwuRj91tcqhjho2_1280.jpg tumblr_o409zwuRj91tcqhjho3_1280.jpg
  6. keef59
    keef59
  7. keef59
    keef59
    Greenville, NC circa 1961 GreenvilleNC1961_02_zpsotbkrivt.jpg GreenvilleNC1961_03_zpshyarclac.jpg
  8. Here in this photo you can see they are using the air starter instead of the hand crank on the Novi.
  9. keef59
    keef59
  10. keef59
    keef59
  11. keef59
    keef59
  12. indyrjc
    indyrjc
    from Indiana
    Thanks for two more great front drive Novi photos, Rootie!
    Is that Cliff Bergere with the posing models in the first attached shot?
    And Radio Gardner is starting the engine the engine with the pneumatic starter in the other photo. I'm still wondering just how well a crank would have worked for anything outside of turning over the engine by hand to check timing or something similar.
    chryslerfan55 and Speedwrench like this.
  13. Rootie Kazoootie
    Rootie Kazoootie
    from Colorado
    You're right, that is Bergere who it seems to have been quite the ladies man.
  14. Deuce Daddy Don
    Deuce Daddy Don
  15. Deuce Daddy Don
    Deuce Daddy Don
  16. Deuce Daddy Don
    Deuce Daddy Don
  17. This is a buddy of mine and his older brother. He has the car back now
  18. KRB52
    KRB52
    from Conneticut
    Well, I guess we know where he spends his time between ambulance calls...
  19. hotrd32
    hotrd32
    from WA
  20. blackrat40
    blackrat40
    Same thing is true for airplanes! I learned to fly in the Navy during the Vietnam fun.
    Bowtie Coupe and loudbang like this.
  21. RichFox
    RichFox
    Airplanes that I flew and airplanes I worked on did not have inertia starters Thank God we didn't have to wind up R2800s when I started, Or the P&W 4000s when I quit.
  22. keef59
    keef59
  23. keef59
    keef59
  24. keef59
    keef59
  25. keef59
    keef59
  26. keef59
    keef59
