Need help identifying this spindle set up Its in my 41 willys . Yes wildwood brakes Spindle mount ? Will get better pictures when it gets above 12 degrees. Thanks Sent from my VS988 using The H.A.M.B. mobile app
Its a jigsaw puzzle to get apart to take the wheel off need something a little easier to change a flat Sent from my VS988 using The H.A.M.B. mobile app
I'm not sure but I think all you need is a non-spindle mount hub. The rotor and hat should bolt to it. Call up Wilwood or look in catalog. Take that super trick away from there and let's see a picture of the hub and rotor from that side. Pat
