30 mpg hot rod ?
Discussion in 'The Hokey Ass Message Board' started by skratch, Oct 19, 2007.
  1. Don West
    Don West
    loooong ago I had a 68 caddy winter beater with 472 that could eake out 8 mpg if I was easy on the throttle. good thing I didn't have far to drive to my min. wage job!
  2. Deuces
    Deuces
    Reminds me of that '74 Sedan DeVille I used to own.... What a hog!!!!:mad::rolleyes:
    Title said it weighed about 5600 pounds....
  3. Pete
    Pete
    My coupe runs on love, it has a Subaru engine.
    AHotRod and gimpyshotrods like this.
  4. gimpyshotrods
    gimpyshotrods
    My Falcon is routinely over 30mpg. Well, if traffic is actually moving, and that is with the carbureted engine.
    The engine that I have on the stand in the garage has full closed-loop digital engine management, including spark control. I will put that in as soon as I get done fixing the damage from a texting teenager.
    It was tested at 199hp, and 247lb-ft, which should be enough to motivate 2460lbs quite nicely.
    The car already has a 6-speed manual transmission, with the top two gears being overdrives. The rear gears are spec'd to work out to be the same as a 2.56:1 set, if it had a 1:1 top gear.
    Efficiency IS power. If you really want both, you won't be able to discuss it on this board.
    AHotRod likes this.
  5. evintho
    evintho
    10 year old thread.......kewl!
    Documented 30 mpg hwy when this motor/trans was in my Mustang. In the 300 hp range too. Now it's in the roadster that's half the weight of the Mustang. 35+??
  6. blowby
    blowby
    from Nicasio Ca
    Many years ago I had an El Camino with a stout 327 4sp. 4:11s. It got 10 mpg. I got the bright idea of adapting Cadillac 4-6-8 valve gear onto it, but before I did I removed the rockers and pushrods from four cylinders. It got 12 mpg. I put it back the way it was.
  7. trollst
    trollst
    AHotRod likes this.
  8. Interesting front view. Please post another pic or three.
  9. Back in the late 70's I had an off topic Chevy Monza with a 262 cu. in. SBC that got 33 mpg with a 4 speed. I put an Erson RV cam in it and a 450 Holley Economaster carb and an SP2P manifold. It would out run my brothers 350/350 Camaro 2 bbl.
    I often wish I would have harvested the 262 and 4-speed for an early 30's hot rod, but you know, times move on...
  10. tfeverfred
    tfeverfred
    Hot Rods and MPG.:rolleyes:
  11. gimpyshotrods
    gimpyshotrods
    Efficiency is power.
    Maximum efficiency is maximum power.
    Everything else is waste.
    AHotRod likes this.
  12. Sheep Dip
    Sheep Dip
    from Central Ca
    Don't bet on it! I've got a way off topic 02 Zo6 that I have driven to Oregon a couple of times on the I-5 corridor and got almost.... not quite 30 mpg. 62 mph taching 1600 rpm
    AHotRod likes this.
  13. gimpyshotrods
    gimpyshotrods
    I don't doubt it.
    Modern engine designs, and complete digital powertrain management systems make old-school folks look like chimps, bashing rocks with sticks.
    AHotRod likes this.
  14. flathead41ford
    flathead41ford
    from Mentor OH
    28MPG with the cruise set at 70ish in my 55 Ford. Aluminum DOHC 4.6, 4R70W and 3.00 rear gears.
    AHotRod likes this.
  15. I'm shooting for GPM.... Gallons Per Mile
