have been collecting parts for a while now time to do some work have boling bro's 5/12 frame will run 283 turbo 350 and 8'' rear coil over rear and tri 4 link some pic's of where i am at now
Looks great ! ...nice work... when i tilt the windshield posts back on a 1930 -'31 i use the '31 vicky, an A 400 or any other slant window's FILLER PANEL, [between the w/s and gastank] ... it is taller and has a gradually indented grove that helps the w/s frame lay flat against the "filler panel", which i call the "bowtie" cause of its shape ... also useing the trailing '30 -'31 door edge [skin], and it's jams, can be done so the door's skin is seen to overlap the jam, then blend the 1" of flat jam into your back panel... gives a factory look to the union of the quarter panel and the back panel... looks kinda like it coulda been a factory aussie, or canadian R P. just spitballing...
Yeah- why isn't this in paint yet? this guy reminds me of my dad yelling at the microwave "come on! I haven't got all minute!" Gonna be a cool ride- slow and steady. Good job
View attachment 3780715 View attachment 3780716 View attachment 3780719 well its been a while back into building car front end axle ect turned up before xmas bought some front brakes, vega steering box and mounting bracket all new from swap meet on weekend
it's a so cal kit comes with rotors, calipers, bearings and seals mounting brackets gm calipers also both ford and gm bolt pattern
So much for the "No trading on Friday"!!!!!!!!! Numbers were well down on the Saturday from previous years, the weather prior wouldn't have helped.
yes they were down i think it is in need of something to boost numbers i am off to the rebel round up in feb its like what kumeu used to be like
Rebel Round up should be good. I live just up the road from the racetrack so a lot easier than getting to Kumeu.
