Technical Best Exhaust Tubing Pipe Cutter?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Jan 2, 2018.
  1. brigrat
    brigrat
    from Wa.St.
    When you do a net search there's many diff. tubing cutters out there, any one have a favorite? Mainly looking for a cutter that will cut exhaust tubing, sometimes steering column pipe. Being able to cut square to tube is a plus! Thanks!
  2. Ridgid Tool pipe cutter , i have a 2-1/8" and a 4"
    plenty of used ones around....put a new cutting wheel on it and you are good for many cuts
  3. lostone
    lostone
    from kansas
  4. gimpyshotrods
    gimpyshotrods
    Ellis band saw.
  5. nunattax
    nunattax
    from IRELAND
    chop saw /mini grinder for scribing
  6. gasser57!
    gasser57!
    Femi makes a great product. Kind of expensive, but I really like the one I purchased. Cleaner cuts than a chop saw too.
    Sent from my SM-G900R4 using The H.A.M.B. mobile app
  7. squirrel
    I use several different tools for cutting exhaust tubing (and other tubing). Usually a chop saw, sometimes a hack saw, and if it's in the car and needs to be cut, I use a chain roller cutter
    samurai mike, j-jock and sunbeam like this.
  8. 48jeep
    48jeep
    I used an Imperial- Eastman tubing cutter for years to cut thin wall ( up to .065 wall )Stainless Steel tubing . There were two different size cutter that were used depending on the diameter of the tube. It is important to use a hardened cutting wheel for stainless and don't force it otherwise you end up threading the tubing rather than cutting it. Another solution is to use a tubing vise with a guide for a hacksaw blade. The second solution is probably best unless you are in the field.
  9. cshades
    cshades
    from wi
    we use a Rigid #30 cutter on our pipe bender in the shop. it cuts perfect straight and seems to last a long time between cutting wheel changes
  10. For cutting out old pipe, I use the cutting torch or the Vise Grip tubing cutter, like Squirrel described.
    For fitting, I normally use a Rigid pipe cutter, and a cutting wheel for fitting pipes like the crossover.
    Bob
