New Stromberg Tool!
Discussion in 'The Hokey Ass Message Board' started by Bruce Lancaster, Jan 24, 2008.
  1. banjorear
    banjorear
    I got a feeling that it may be easier for you to list the things you DON't have or collect than you do.
    I'm always impressed with your pictures. GAWD DAMN you've got some cool stuff.
  2. Bluto
    Bluto
    I can't find my carb tools either
    I've got Stromberg jet tool sockets not the ittle stamped tin stuff ..sockets.... when I find'em I post those too.....
    And there'sa Stromberg SW Booster kit here too.......
    Moving issa bitch.........
  3. 18n57
    18n57
    Bruce, the mental image of your poor wife flailing away on the pump caused me a severe belly laugh and possibly a rupture. Damn !! I'm gonna haf ta put my feet up and rest for a while:):)
  4. Yes it is, I am still unpacking stuff I boxed 10 years ago!
  5. jonny o
    jonny o
    Congrats on working mid-evil style. Who needs an compressor anyway?
  6. uncle max
    uncle max
    Nine years ago! My old Dad told me, time gathers momentum!
    kidcampbell71 likes this.
  7. blowby
    blowby
    from Nicasio Ca
    Hi Max,
    Great tip on blocked pump tubes.
    I posted a thread the other day and got no reply. Can you tell me if there is an adjustment on 97s to adjust the high idle when on the choke? Don't see a separate screw like later carbs.
  8. uncle max
    uncle max
    If the accelerator pump link is on the "S" ball of throttle arm, speed should increase when the choke is pulled, with the help of the chokekicker linkage. If it's on the "W" ball, you'll probably have to dial it down. If it's still way too fast, you may have worn bushings and/or throttleshaft.
  9. steel rebel
    steel rebel
    Dude I rebuilt four of them just as Bruce said and they work perfectly. They even idle. Oh I had to take the filters out to lighten up the spark plugs. I now have screen door filters. That keeps the borders out.
  10. williebill
    williebill
    Another reason to love the HAMB.... seeing this thread and going back to reread it from the beginning again.
    You folks are priceless....
  11. pitman
    pitman
    Willie, you nail it! Wisdom lurks behind clever tales by Obie-wan! (Mssr. Lancaster)
  12. blowby
    blowby
    from Nicasio Ca
    Thanks Max. My pump link is on the ball closest to the throttle shaft. The problem I have is, when cold, it takes a bunch of choke pull to raise the rpms and get an idle, then when I pull away it goes very rich, I have to push the choke in to avoid misfire, then when I come to a stop sign I have to pull the choke again to get an idle. All this goes away once warm, nice steady slow idle. If I could get a faster idle on the choke without the choke plate being as closed, I think that would help.
