Hello, I'm trying to install this 2 bolt distributor and I'm having trouble identifying the correct wiring schematic. My distributor which is a 5072001H has a red, brown and yellow wire while all the pictures I've found online has red, green, and brown wiring. Is it as simple as the yellow and green are the same? Thanks
it would appear that the red is your 12 volt feed from the ignition, brown should be your engine ground and that yellow should connect to the coil from what I could see from the Wizard's diagrams fwiw
