Projects 1955 Chevy Southeast Gassers Build
Discussion in 'Traditional Hot Rods' started by Zak Hall, Oct 29, 2017.
  1. Zak Hall
    Zak Hall
    IMG_0571.JPG IMG_0598.JPG IMG_0599.JPG IMG_0602.JPG IMG_0603.JPG IMG_0605.JPG This is the build thread of my dad Ron's 55 Chevy 150 post car. Building to run Southeast Gassers D Gas. We've just started on it, hoping to have it done for next season.
  2. Higgy's Henry
    Higgy's Henry
  3. southcross2631
    southcross2631
    I'll be watching. What are you going use for a motor ?
    Fiddle Picker, Zak Hall and loudbang like this.
  4. You guys have a good start. It never ceases to amaze me how fast you accomplish things. Inspiration to get mine track ready for the spring.
  5. jim snow
    jim snow
    Good on you guys. Can't wait to see how this one turns out. Snowman
  6. loudbang
    Good another of your build threads to follow along. :)
    Fiddle Picker, mad mikey and Zak Hall like this.
  7. Zak Hall
    Zak Hall
    This one will be small block powered.
  8. rustednutz
    rustednutz
    from tulsa, ok
    Ought to be fun. What trans are you planning?
    Fiddle Picker and Zak Hall like this.
  9. Subscribed ...........
    Fiddle Picker likes this.
  10. Zak Hall
    Zak Hall
    IMG_8738.JPG Jerico dr4, he's already got the transmission from Bob Treadway.
  11. jim snow
    jim snow
    And a Bud tall pop top can!
  12. Eric1967
    Eric1967
    from Union, Mo
    I been watching some of the southeast gasser videos on YouTube. Looks like lots of fun. Keep us posted
    Sent from my SAMSUNG-SM-G900A using The H.A.M.B. mobile app
  13. southcross2631
    southcross2631
    I see 200 lbs off the car setting on the bench beside the transmission.
  14. Zak Hall
    Zak Hall
    That's in the living room, gotta keep the good parts inside. Lol
  15. Zak Hall
    Zak Hall
    That's the overflow!
  16. southcross2631
    southcross2631
    Little motor , light car? That's my plan for D/Gas. I am shooting for 2770 with me in the car. I am going to use a 297 inch motor with stacks.
  17. Ft.ValloniaStreaker
    Ft.ValloniaStreaker
    Better wear your steel toed boots and a heavy jacket....3,000 min. in D/G , but doesn't matter till you run 7.25
    Fiddle Picker, catdad49 and loudbang like this.
  18. savannahDan
    savannahDan
    seems like I may remember talk of the 3000 lb minimum changing, maybe down to 2800.
    I wouldn't expect to see many 280 inch motors, so maybe that case would be a 3000 lb car, 300 cubes, with iron heads and injection to allow it to run at 2800 lbs. Maybe Quain can clarify.
    Might end up adding A/C and a stereo to get my Falcon to make weight o_O
    Outback, brEad, Fiddle Picker and 3 others like this.
  19. Ft.ValloniaStreaker
    Ft.ValloniaStreaker
    Factory weight on my Chevy II was 2,500#, so trading a 6cyl. 3 spd. to a 301 and 4spd. still leaves me light. Not counting that pile of scrap in back of the shop.
  20. southcross2631
    southcross2631
    Quain has changed the minimum for next season . Plus a 200 lb break for stack injection. 2970 with the 297 inch motor minus 200 for stack injection . 2770 it is. My Morris minor should weigh around 2400 ready to go. I weigh about 205 . So a little ballast and I am at the weight. Iron heads get another 50 lbs. but that is not a trade off for a set of CNC ported AFR heads.
  21. Zak Hall
    Zak Hall
    Yeah it's gonna be 301ci small block with fuel injection. So shooting for around 2800 with dad in the car.
  22. Mike Colemire
    Mike Colemire
    I'm glad to see this thread. It'll inspire me this winter!
    Fiddle Picker, loudbang and Zak Hall like this.
  23. Right down to the bare shell to start with, I'll stay tuned and watch the progress.
  24. Higgy's Henry
    Higgy's Henry
    It doesn't matter what the minimum weight is for the class. You are entitled to the weight breaks like stack injection(2oolbs), period correct intake(50lbs), iron heads(50lbs) to be subtracted from your pounds per cubic inch weight even if you end up below the class minimum.
  25. Zak Hall
    Zak Hall
    Mocking up dads car. 10% engine setback, enderle injection, magneto, and 301ci of SBC. I think this is gonna be a killer car for him. Excited to start on it.
  26. AHotRod
    AHotRod
    I'm watching to Zak .... your gonna run a 6.50 ring & pinion?
    gonzo, Fiddle Picker and loudbang like this.
  27. Zak Hall
    Zak Hall
    Yeah that's what dads planning I think.
  28. southcross2631
    southcross2631
    We used to run a 6.50 gear in a G/Gas 67 Firebird with a 2.95 1st gear. We ran a 13/31 tire at 3450 lbs and a 306 inch motor. Car ran 6.80's which was under the NHRA index at the time.
    That was in the mid 70's. We used a Dana 60 rear. We would change flywheel weight to compensate for the track conditions. We carried 3 flywheels with us all the time. Now days track prep is usually not an issue.
  29. Zak Hall
    Zak Hall
    IMG_0843.JPG Got the front tires mounted today. Gotta pick up some parts from Ron Pope Thursday so we can start putting the front axle under it
  30. Zak Hall
    Zak Hall
    Got our stuff from Ron, and mocked up the ride height. If we don't change the front frame, with a 4" drop axle it'll be 15" from the rocker to the ground. Dad wants it at 12.5" so we're gonna have to modify the frame. Gonna get the body and frame blasted Saturday so it'll be clean. It's coming together.
