Technical Is anyone still using 4 speed transmissions?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Apr 13, 2017.
  1. clem
    clem
    “IS ANYONE STILL USING 4 SPEED TRANSMISSIONS?”
    Still using a 3 speed........
  2. IMG_20171005_085930714.jpg M22, Hurst RamRod.
    Ron Funkhouser and wheeldog57 like this.
  3. 327Eric
    327Eric
    Four on the floor for me.
  4. In 1959 I swapped complete Olds engines, Hydramatic trannys, and rear ends, into a couple of cars, and my friends thought that was a smart way to go. There were few inexpensive, strong, 3 or 4 spd trannys available so we used what we thought would hold together. Nobody cared.
    Bob
  5. dartracer
    dartracer
    Yep A833 behind the hemi
  6. ZAPPER68
    ZAPPER68
    from BC
    Yup...an M21 in my 68 Zapper, M21 in my 66 L72 Biscayne, M22 in my 55 Chev Gasser and a 833 in my 66 Hemi Satellite...
    mgtstumpy and 31hotrodguy like this.
  7. deuce666
    deuce666
    from Oregon
    I’m just finishing up a build on a 32 coupe. Running a super T-10.
  8. 31hotrodguy
    31hotrodguy
    Have a M22 in my daily driver 57. Race car has a A833 4spd. 57 wagon (not running) has a Super T10. Would love an aftermarket 5spd in my driver but have never quite had the funds for it.
    Sent from my SM-G550T using The H.A.M.B. mobile app
  9. phat rat
    phat rat
    My T has an A833
    31hotrodguy likes this.
  10. jimmy959
    jimmy959
    My '57 has a 327, T-10, Hurst shifter.
  11. jamesgs4
    jamesgs4
    from denver
    gave away the th350 I had in the garage and picked up a muncie from a 67 vette. hot rods have 3 pedals is what i've heard.
    egads likes this.
  12. El Jefe hemi
    El Jefe hemi
    from BC Canada
    I am building a 30’ Ford roadster with a 354 hemi (approx 410 hp) and am now deciding on a manual tranny. Trying to keep my build 60’s style and am thinking an A833 (Passon o/d)? Looking for thoughts on how the shifter will sit in place and any other advice - pros/cons ? I will be doing a fair amount of highway cruising.
  13. DDDenny
    Yep.....Muncie out of a 69 Camaro with Hurst shifter.
    Ron Funkhouser and mgtstumpy like this.
  15. '51 Norm
    '51 Norm
    from colorado
    Don,
    I really like the interior in the car!
    What is the steering wheel out of? I have a similar one out of an early '60s Caddy that I am planning on putting in my '51 GMC.
    Norm
  16. missysdad1
    missysdad1
    Yup... The new Arin Cee Roadster has a wide ratio Muncie M20 - a little too new to be "period correct" but it's bulletproof and fun to drive, and those are my primary considerations.
    mgtstumpy likes this.
  17. Thanks. The wheel is from a 1961 Chevy Impala. I had a 59 Impala in it for a while but everyone uses those so I wanted to be a little bit different. I have done the door panels since that photo was taken. I guess you can tell that I love yellow.
  18. '51 Norm
    '51 Norm
    from colorado
    So do I. I'd show you a picture of the firewall on my GTO but since it is too new I'd get flamed for it.
    I'd show the rest of the car but the firewall is the only part that is done.
  19. egads
    egads
    Su model a 003.JPG per T 10 in my 31
  20. Vanness
    Vanness
    86AFA0AC-1224-4339-9702-EDE79457C067.jpeg 22CAF221-A751-4C92-81EB-A9B160968026.jpeg Yeah boy. All cars should be stick. 55 with a 4 speed. Don’t ask what motor ....
  21. egads
    egads
  22. teardrop
    teardrop
    4 speed Moss. late 50's. (I think)
  23. mopacltd
    mopacltd
    23 spline A833 behind the 426 Hemi here
    mgtstumpy and Vanness like this.
  24. woodbutcher
    woodbutcher
    :D Had a Muncie and a 327 in a 53 Stude.Until a drunken idiot rear ended me.That WAS a fun ride.
    Good luck.have fun.Be safe,
    Leo
  25. no55mad
    no55mad
    Can't take the credit for the build and the builder may have been advised by the Nailhead guru Russ Martin. One of the last 4 speeds used, out of an early 80's Camaro. Real low first and second gear which allows for a high geared rear; ~3.0:1. With 16" rear wheels, it is like having an overdrive and works great. Especially after getting rid of the leak prone hydraulic throw out bearing and going with a slave cylinder. MarchMeet15 016.JPG
  26. Anderson
    Anderson
    M20 in my roadster
  27. jimmy six
    jimmy six
    At this GNRS I Saw more 3 pedal cars than I've ever seen... The 4 speed is definately not dead....
  28. El Jefe hemi
    El Jefe hemi
    from BC Canada
  29. thunderplex
    thunderplex
    1962 Rambler Classic 400, 343 V8, 4-speed
    Bowtie Coupe likes this.
  30. thunderplex
    thunderplex
    1930 Model A, 283 w/2x4s, 4-speed
    Bowtie Coupe and 40FORDPU like this.
