1957 Chrysler 392 HEMI Engine, Engine # 3NE57, Genuine 1957 300 “C“ This particular engine was saved by an enthusiast in its original Low mileage condition. It has been completely rebuilt with stock bore and stroke, new rings and bearings Original Adjustable Rockers Race Cams Inc. Solid Lifter Camshaft, New Valve springs new solid lifters, 2 x 650 cfm Competition Carbs, BBC Water Pump, Electric Fuel Pump. Turbo 350 Trans with 2000 rpm stall converter. Original 300 “C” Distributor Custom Frame With Independent Front Suspension and 4 Link Triangulated, 8.8 Limited Slip Rear End , Pro shock/Adjustable Springs all around. Four Wheel Disc Brakes, Rack and Pinion Steering, 1926 Model “T” Roadster Fiberglas Body, 32 Ford Grill shell, Aluminum Radiator, Electric Fan, Trans cooler, Tilt Wheel, Wilwood Master cylinder Both Doors and Deck lid Open, Bear Claw latches, Hidden latch on deck lid. 16 Gal Gas tank. Approx 4,000 miles since built Car was featured in “RodAuthority. Com” In May 2013 772-475-6117
