Technical Clean Coupe into a roadster possibilities...???
Discussion in 'Traditional Hot Rods' started by Wurger, Oct 17, 2017.
  1. Wurger
    Wurger
    Over the weekend I found in 1929 Plymouth that appears to have been turned into a truck during the war the farmer thought that it didn’t have a roof but I found one That might be a match ??? I’m not sure if it is ...but aside from this I also found what appears to be a 1929 Plymouth roadster cowl. I’m not too hard on the coupster concept but could a clean roadster be made out of a coupe if in fact I used a roadster Cowl, ( the roof is cut so I would not feel to bad...) I know the doors will be a little bit tall but perhaps that can be fixed.... One of these days I’ll quit finding shit and I’ll be able to finish the projects I already have lmao
    P.S The 31 Buick in the back isn’t for sale...
    [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. bobo1
    bobo1
    from France
    Dza+×!1+#××÷#@#"×!
    "÷"2!aux
    !+""?2s2 de xavier zxzzf #"÷"×!!!!+ àquelle.?×#+
    jerseyboy likes this.
  3. Torana68
    Torana68
    from Australia
    say again, over.
    tartar_sammich, Jet96 and Wurger like this.
  4. bobo1
    bobo1
    from France
    Sorry it's error the message is wrote in my poket it's the problème with iPhone
    Sent from my SM-A510F using The H.A.M.B. mobile app
  5. Nice score!
    The doors may be a little work as the roadster cowl looks like it has a bit more curve at the top. Mock it up and then you will have a better idea.
    Wurger likes this.
  6. 62sedan
    62sedan
    from Texas
    Just wondering if anyone can decipher or shed some meaning regarding the top line from the tag?
  7. This could be fun....
    Wurger likes this.
  8. Perhaps it is not an American built car ( USA) like Argentine or something? Just a guess.
    As for roadster lots of coupe got the roof chopped off way back when. If you really want it to look roadster you have to play with the belt line a little bit and us roadster windshield stations, or maybe a Halloc (SP?) style windshield.
    Personally I think if I had a coupe that needed a top I may make a Cabriolet out of it, and a Carson style top. Best of both worlds bad weather bolt the top on and roll the windows up good weather roll em down and remove the top.
    biggeorge and Wurger like this.
  9. sloppy jalopies
    sloppy jalopies
    Australian and Argentinian fords were right hand drive...
    the mopars had lots of front sheetmetal combinations, ex. PB... PD...PE etc.
  10. There ya go. ;)
  11. Wurger
    Wurger
    WOW!!! I thought the "p.o.s" steering wheel was homemade, it looked to unsoild and to thick to me, I was dead wrong!
  12. Wurger
    Wurger
    I wonder how difficult that would be.... If I'm not mistaken the doors would remain the same for the most part but the back post would be cut and hinged in some form or fashion...
  13. For a cabriolet? You just build the channel into the roof. Clip both pillars off the doors.
    biggeorge likes this.
  14. Wurger
    Wurger
    Any threads on this that you know of???
  15. jcd58fleetside
    jcd58fleetside
    I wonder if the car came from Canada. I see Washington plates. Could be Ministry of DEFence. Followed by Ministry of INDian affairs or some other acronym.
  16. low budget
    low budget
    from Central Ky
    Does that say "PLYOUTH" on the hood?
  17. pitman
    pitman
    Beaner's got the good strategy!
    Wurger likes this.
  18. Wurger
    Wurger
    Spelling isn’t this farmers strong subject lol but yes it sure does!
  19. low budget
    low budget
    from Central Ky
    Character,;)
  20. SR100
    SR100
    The top line is a trademark notice in Spanish: "Marca de Fábrica Mecánica Industrial Registrada", probably to facilitate export to Mexico (but all Plymouths of that era seem to have the same plate.)
  21. Gary Addcox
    Gary Addcox
    What do the PB, PD, and PF designate ? I'm a Ford Deuce freak. Thanks for the headsup.
  22. RichFox
    RichFox
    PB was the 1932 Plymouth. Last year for the four cylinder.
  23. sloppy jalopies
    sloppy jalopies
    p = Plymouth... the next letter was the code for front fender / hood / trim combination...
  24. Not that I know of, but you can figure it out, thiMk. ;)
    The last Cabri I worked on was a '34 Ford ( maybe it was a '33 LOL) with a Carson style top and all it had soft rubber door seal along the top of the window. But flexible window channel ( like you get from JC Whittney) attached to the top frame should be pretty easy too.
  25. RichFox
    RichFox
    Not quite. The PA was the 29 nd 30 four cylinder car with poured bearings and no counterweights. In 32 the PB had insert main bearings and a counterweighted crank. In 33 Plymouth came out with the PC which was a six cylinder engine that more or less lasted until '59. Soon Chrysler decided they needed a longer car to allow fender mounted spare tires. That was the PD. An up scale Plymouth.
    dwollam and biggeorge like this.
  26. jerseyboy
    jerseyboy
    Wurger likes this.
