What is a fair price for a fairly clean, running and driving Model A chassis (no body)? Thanks Sent from my iPhone using The H.A.M.B. mobile app
I've been looking for one for my son, have seen them mostly in the 1500-2500 range depending on completeness and condition. ALL of them are without titles, which depending on your state could cause some problems because I'm sure the seller is keeping the body / title that goes with that numbered chassis. Good luck, Mitch.
I lucked into one a couple years ago for $500, complete and engine turning but still needing some work, it's running now. I have seen a few at local swap meets running for $1200-$1600 but they're not from a restoration or anything, I've seen ones from under restored cars, sometimes with juice brakes and new tires and other such upgrades as high as $4000, so there's a range but I agree with most saying the average is $1500-$2500.
Thanks for the input. Possibly buying with the thought of finding the right body next. Sent from my iPhone using H.A.M.B.
As others mentioned the title thing can be a nightmare. If you have the chassis and engine, you have the part with the VIN, but when you go to try and get a title the guy that kept the body will have his car already titled with the VIN that is on your parts. I wouldn't pay anything for a chassis unless I also got the title, and a lady from the DMV here told me that the part with the number on it is the part that matters, so the chassis should never be sold. She said even if you use an aftermarket chassis you must keep the original in your possession so you have the numbered part.
