1964 ford pickup. Truck started life as a long bed 2wd, but is now a unibody imposter powered by a GM 403ci V8, and auto trans (trans rebuilt 80 miles ago). Bagged all the way around with 2 tanks, 2 Viar 444s, and an old style 4 switch setup. Satin paint finished pin striping in and out. Interior is clean and simple. Tires were replaced 200 miles ago. Rewired the entire truck with a Painless harness 2 years ago, and at that time replaced all gauges. Besides not having windshield wipers EVERYTHING works properly. This is a completed truck not a project. With it comes a new in box aftermarket AC set up. New in box power windows. Truck runs good and turns heads. Fun rig! The Issues: Has slow air leak. One corner will bleed off over night. Very small oil leak. I just did the rear main with the trany rebuild so I assume it’s the intake. Every now and again starter grinds on start up. $12k No trades. Thank you for looking. 928-750-0060
BUMP!! I forgot to mention that rotors, drums, pads, shoes, wheel cylinders, and axle seals were replaced less than 200 miles ago. Have a kick ass weekend folks! -Chad
