Technical Question concerninc 1928 Ford filler neck
Discussion in 'Traditional Hot Rods' started by FlatJan, Oct 6, 2017.
  1. FlatJan
    FlatJan
    Hi Hambers,
    does anybody know what thread is on the 1928 Model A Ford fuel filler neck?
    thank you
    Jan
  2. '28 Ford didn't have a filler neck, just a bung on the top of the tank that a gas cap screwed to. Unless you are thinking of something that works with the tank relocated.
  3. sloppy jalopies
    sloppy jalopies
    henry made lots of '28-'29s,
    the threads were sometimes rolled into the steel or brass not machined, he may have used his own thread...
  4. FlatJan
    FlatJan
    @p&b:sure i mean that bung ;)
    @sloppy j: ok thank you
    i wanted to use those as exhaust cut outs. As it seems those bungs are hard to get i thought of getting repop caps and making the bungs on my lathe. But without the thread info it´s kinda difficult
  5. Budget36
    Budget36
    Checked it with a thread gauge yet?...Might match something your lathe will do.
  6. Kiwi 4d
    Kiwi 4d
    Are you wanting to repair a damaged tank thread? If so a bastard thread repair file may do the trick with 8 threads to choose from surely one will be a close match.
  7. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    If you're trying to fit a new gas cap, the repros often don't fit the threaded neck. If that's your problem, try to find a good original. Don't forget a new gasket.
