Technical HEI No Spark
Discussion in 'Traditional Hot Rods' started by crosswindjoe, Oct 2, 2017.
  1. crosswindjoe
    crosswindjoe
    My 52 Chevy with a 350 and 700R4 quits running when it gets hot. I have replaced the module and coil (one at a time) and it still acts the same. It has fuel at the carb when it quits and will start and run if it cools for 45 minutes or so. It also has power at the distributor when it quits. Any ideas?
  2. saltflats
    saltflats
    from Missouri
    Pick up coil ?
  3. Sheep Dip
    Sheep Dip
    from Central Ca
    Is your power to the HEI a full 12 volts dedicated feed? If it's less than 12 volts it will shut it down.
    LOU WELLS likes this.
  4. Sheep Dip
    Sheep Dip
    from Central Ca
    If your 12 volts passes thru the fuse block bypass it with a direct feed and see if it cures it.
  5. A 10 gauge wire to feed 12 volts. Determine that the ground to the coil is good. This would include the contact that is under one of the screws that hold the coil in the cap.
    LOU WELLS and ClayMart like this.
  6. mohead1
    mohead1
    Alot of times its the internals....check, clean, dielectric grease, yada yada...otherwise they are pretty reliable
    Sent from my SM-G900V using Tapatalk
    j-jock likes this.
  7. partssaloon
    partssaloon
    Look at the bottom side of your rotor
  8. A little dab of dielectric grease on the terminals is OK. But if you're talking about what goes on the underside of the module you'll want to use thermal paste. It's a completely different compound that's made to promote heat transfer away from the module. Dielectric grease is intended to seal electrical terminals and connectors from moisture and to prevent corrosion.
    fauj, j-jock and scrap metal 48 like this.
  9. Joe H
    Joe H
    How much power at the distributor when it quits?
    HEI needs full 12 volts for starting and full battery/alternator output when running from a 10 to 12 gauge wire direct off the key switch. The key switch needs power right off the battery.
    Replace module with good used GM unit, add thermo grease to back side to transfer heat away, clean the coil ground in the cap, and check the two small green and yellow wires coming off the pick up deep inside the distributor. The pick up unit rotates with the vacuum advance, so the wires are moving all the time and do break every now and then.
    Hot wire the distributor right off the battery next time it dies and see if it will start.
    trollst likes this.
  10. Check the coil for a loose wire. HRP
  11. I had the same problem.... and have read on other boards that HEI modules DO simply quit when they get hot. I got an MSD "Heat" electronic replacement module, and the problem went away. Sooooooo.....
  12. mohead1
    mohead1
    The modules will suddenly quit, for no reason. Never.said dielectric grease under module. Module comes w a special sealant usually
  13. Mr48chev
    Correct terminal end on the wire to connect to the Hei? I had a hell of a time with one that had a slide connector on the wire rather then the HEI connector. It would invariably not get good contact after about 20 minutes of driving and usually at 3 am in a rain storm.
    I've got the pages out of a bulletin NAPA put out 30 + years ago on troubleshooting HEI distributors on my photobucket . There are eight pages in the booklet and it bailed me out a number of times troubleshooting these things and even saved a buddy a tow job on a road trip in his motorhome as he had a copy along that I gave him. http://s173.photobucket.com/user/mr48chev/library/Napa HEI service info bulletin?sort=3&page=1
    LOU WELLS and pat59 like this.
  14. Hey Mr 48.... as usual, photobucket continues to screw everybody... I have an ad blocker on my 'puter, and when I click your link, pissbucket says "you have an ad blocker and we ain't gonna let you see anything on here unless you turn off your ad blocker...".... assjacks.....
    SmugMug is a much better AD FREE web photo hosting site.. that's what I use.. fully configurable.. etc., etc., ....
  15. Mr48chev
    Napaheipages001.jpg Napaheipages2003.jpg I've got a smug mug account but haven't transferred them there as no one has complained before.
  16. Mr48chev
    Hopefully in order napaheipages3001.jpg Napaheipages4001.jpg Napaheipages5001.jpg
  17. Mr48chev
    NapaHeipages10001.jpg NapaHeipages11001.jpg NapaHeipages12001.jpg NapaHeipages10001.jpg NapaHeipages11001.jpg NapaHeipages12001.jpg That should be all eight of them.
  18. Bandit Billy
    Bandit Billy
    Nearly on entire page and no one told the OP to put in points?
    46international likes this.
  19. My first thought was HEI module
    Second thought pickup coil
    It tells HEI when to fire.
    Sent from my SM-G900V using The H.A.M.B. mobile app
  20. cru_zn_29
    cru_zn_29
    Check your rotor on the bottom for a burn hole and killing your spark on the dist shaft.
  21. tinkirk
    tinkirk
    Pull the dist. Replace the pickup coil
    You already did the coil and module
    Tinkirk/Terry
  22. deathrowdave
    deathrowdave
    from NKy
    I have to say I have helped many a stranded rodder because of a burnt up rotor on HEI . That may not be your issue but just replace it with a quality part now or later on the rotor will be your issue when you really don't want it to be .
  23. bobkatrods
    bobkatrods
    from aledo tx
    I have run a bunch of HEI distributors yes if the module heats up it will shutdown and start after cool down Also they will run down to about 10 volts, anything less than 10 volts they will shutdown. I had one unit that would shut down when warm randomly.Turned out after a lot of troubleshooting it was the pick up coil, seemed to be when the unit got warm/hot one of the wires would move slightly,,it had a broken wire and only showed up when the wired moved ever so slightly,found it by moving the wire and checking with a meter it would go Open,,Replaced the pickup and never had issues again
  24. Experienced the broken wire before. Would work intermittently, but found it and fixed it/ Broken in the connector.
  25. crosswindjoe
    crosswindjoe
    Thanks for all the comments. A new pickup coil seems to have fixed it. The Eichlin bulletin is also very helpful.
  26. great you found it, I was going to say I have also had a broken wire in the coil.
  27. The ground system of HEI's is one of the most common causes of an erratic performing distributor.
