Ford 2.3L 4 cylinder SOHV engine wtih a stock 2bl carb,and 4 spd manual transmission. with only 6500 miles Has new brakes, side load exhaust, Hurst T shifter, top and side windows but I have never used them. Gelcoat is showing some black splocthes is a few areas, may be bleed through from the mold process, don't know why. Has full top, 15 x 8 rear, 14x 8 front ARE wheels. Custom front suspension. Ford differential, rack and pinion steering with front disc brakes, rear drum, Special upgraded seats ordered from the factory, Two speed wipers (3 blades Motor not installed) - Halogen headlights, Leather wrapped steering wheel. push button start.
