Death shake straight axle. Why?
Discussion in 'The Hokey Ass Message Board' started by merctruck, Mar 15, 2012.
  1. larry k
    larry k
    do this---do that---:confused: to get the final answer, call dick spadaro ,he is a early ford suspension master,,,,, !,race cars, hot rods, drag cars he has set "em" all up at some point his life, when is comes to suspension he sees all ,, knows all !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:eek:
  2. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Without pictures showing the front end geometery, setup, and condition of components and wheels, it's pretty damn hard to diagnose the problem. Pics, or there is no death wobble! :)
  3. BLUDICE
    BLUDICE
    Install a steering damper as recommended by most front axle componets suppliers.
    Cooter likes this.
  4. willys1
    willys1
    from South Ga
    Did I miss what type of truck we are talking about?
  5. banjorear
    banjorear
    Not always.
  6. papastoyss
    papastoyss
    The steering stabilizer most commonly used on rods is actually a steering damper from an air cooled VW. There are several types, Bus, Std. Bug, Super Beetle w/different mounting arrangements. If you have no worn suspension parts or tire issues a stabilizer would be a low price upgrade. I worked on VWs for many years & know for a fact you can't hardly hold one in the road w/a bad steering damper.
    Cooter likes this.
  7. TheTrailerGuy
    TheTrailerGuy
    Yep, new Speedway motors piece.
  8. bulletproof1
    bulletproof1
    from tulsa okla
    make sure tires are good ,no broke belts or out of balance ...make sure all steering parts are in good condition, set caster at 4 degrees.
  9. richie rebel
    richie rebel
    my problem was a bad steering box(vega style) bad bearing in the pitman arm shaft
  10. gerrald meacham
    gerrald meacham
    lower the air pressure in one tire to about 15 lbs see how it does. front tire
  11. Leaning the axle back creates "positive" caster.
    You are right my bad but I still run 1/2 degree neg camber in mine but each to their own
  12. I was able to resolve the problem after I followed lots of advice that resulted in replacing every part in the front end and realigning it. After many bald spots from pulling my hair out I said screw it and bought new tires and solved the problem. Thanks to all that offered advice and solutions. This is why I love the H.A.M.B. so much people are always willing to help a fellow rodder in need.
  13. Mean Lean
    Mean Lean
    Google scrub factor and it makes logic
