Repo Fulton Visor SUCKS
Discussion in 'The Hokey Ass Message Board' started by theorangecouch, Apr 26, 2010.
  1. 48panel
    48panel
    from portland
    Hello MT
    I would like to get some more info do you have a wed site or can you send me a pm so I can give you my email or phone # I have a 48 dodge panel and am interested in a 1000 series visor but have some questions I cant figure out the massage thing
    thanks
    Mike
  2. 41FordVert
    41FordVert
    ImageUploadedByH.A.M.B.1425005867.242422.jpg ImageUploadedByH.A.M.B.1425005910.941821.jpg
    Anyone know what visor I have??
    Thanks
  3. Without seeing detailed close up pictures.....
    It looks like an early "Dieterich" standard visor.
    The "Dieterich" Deluxe has stainless trim across the leading edge.
    The "Dieterich Standard only has stainless trim up the middle.
    The stainless molding up the middle of your visor is a dead giveaway for a Dieterich.
    Most Dieterich visors use stainless end caps to secure them to the drip rails.
    Looks like your visor is molded to fit the drip rails so it could be a combination of parts from a few different visors.
  4. Jersey Joe 67
    Jersey Joe 67
    from J Town
    Is it possible to get replacement parts like the center trim on these visors.
    I'm looking for one for my 46 Super Deluxe Coupe.
  5. Ride77
    Ride77
    Looking for a visor for my 47 fleet line. Fulton 700. ImageUploadedByH.A.M.B.1448734839.673481.jpg ImageUploadedByH.A.M.B.1448734864.622825.jpg
  6. Hobgoblin
    Hobgoblin
    Mother Trucker, I am Currently looking at a Fulton Visor for a 51' Buick Roadmaster from photos of the visor it looks like a 800 series. Do you know this series fits this application. The the Roadmaster is also a one-piece windsheild so i would have to fit one of these roof mounts. Would you happen to have any information on these roof mounts? Thanks
  7. t2dfyre
    t2dfyre
    Can anyone recommend a visor for a 1940 plymouth P10 Sedan?? Thank you
    [email protected]
    (951) 543-2376
  8. TwoFeathers
    TwoFeathers
    I just picked up a 1951 and I am looking for a visor for it. Anyone have one for sale?
  9. 5window
    5window
    Good luck with your project. You might want to try A-an intro-see the sticky's at the top. and B: the Want Ads. An old general thread like this probably won't get you too many results.
  10. I picked up this one at a swap meet this fall. 20160924_161609.jpg @MotherTrucker Will this work on my 1947 chevy fleetline? Also what model is it.
  11. TyDavis........re your question about a visor for a 1940 Plymouth, the visor I had on my 1941 Plymouth was as a found out on this thread a Fulton 1000 series visor....1940 to 1948 Plymouth and I am reasonably sure other 40-48 Mopars all had the same size dimensions across the front windscreen..........Plymouths certainly did............I posted a few pics on this thread earlier so check them out....heres another..........regards, andyd.
  12. jeffgies
    jeffgies
    Does anyone know whether all 700/800 series dog bones were made from aluminum. (Without going out to the shop to check, I'm not certain which I have.) I want to install the visor I have on a 51 F1, but have to modify the brackets slightly and my aluminum welding skills aren't that hot. The report brackets are a bit steep at $75 each!
  13. Aluminum.
    TIG is the only way to weld on them with any success.
  14. miwi
    miwi
    from Germany
    @MotherTrucker
    I have a 700 or 800 Fulton that doesn't fit my F1 due because the F1 has no split windscreen.. Can I convert it with a different Center Piece so that it would fit?
    THanks for your help
  15. The roof mount center section will work on your F1.
    jazz1 and turboroadster like this.
  16. roddin-shack
    roddin-shack
    MT is this a Dieterich? Fits perfect on my 50 Monarch but it does not have anny markings. I have taken it off as I did not like the looks of it on the car. Thanks In Advance For Any Information. Larry
  17. BigMix
    BigMix
    IMG_1032_2.JPG I think this is a 800 ,Question are the center bottom interchangeable to the Slit style mount type , I am missing some pieces to mount the Pinch Clips to the center of my split window ,Also I noticed when I took it apart I am missing the connecting Rods ,does anyone know where I can get that replacement part ,thanks
    Cadillac Jack likes this.
  18. "MT is this a Dieterich? Fits perfect on my 50 Monarch but it does not have anny markings. I have taken it off as I did not like the looks of it on the car. Thanks In Advance For Any Information. Larry"
    Yes that sure looks like an early Dieterich with the "Peckat" style end brackets to me.
  19. roddin-shack
    roddin-shack
    Thank You. Larry
  20. miwi
    miwi
    from Germany
  21. Peter Hennessy
    Peter Hennessy
    Hi MT
    Hi I was wondering if you have a Fulton visor to to fit a 1954 Oldsmobile 98 I live in New Zealand would you be able to post
    Thanks Pete
  22. jeffgies
    jeffgies
    Does anyone know who the manufacturer of the repo visors is? I'm just looking to get a set of steel side brackets that I can mod and do exactly like Miwi plans to do for a 51 F1.
  23. Someone requested more info. on special application dog bone brackets for the Fulton 700 & 800 series visors.
    The Fulton 800 series EE brackets were used on hardtop cars
    {without drip rails on the body}.
    These brackets do not mount on the inner door jamb.
    They mount directly to the upper windshield pillars.
  24. The Fulton 800 " Convertible " dog bone brackets also mount directly to the upper windshield pillars of convertible cars.
  25. zzzzfultonc.jpg The Fulton 700 "Convertible" brackets also mount directly to the upper windshield pillars...
  26. Stefan1
    Stefan1
    Hi Mother Trucker,
    I'am from Germany and I'm searching for a Fulton visor for my 1940 Chevy 1/2 ton Truck ...
    Can you please give me advice which visor will fit and where i can get one for a reasonable price and shipping to Germany.......????
  27. manyolcars
    manyolcars
    When I was a kid I thought those visors looked cool but I learned they have no place in the traditional hotrod world. They are for lowriders and garbage wagons
  28. flatheadpete
    flatheadpete
    from Burton, MI
    Oh man...this bumped just in time. My sister-in-law's grandfather gave me a really nice visor that he took off his '51 Ford some 50+ years ago. I get it tonight. Pics to follow this evening.
  29. flatheadpete
    flatheadpete
    from Burton, MI
    Here's what I have. I'd love to have a set of instructions. @MotherTrucker
    And yes...it's just sitting on there, in the rain gutters.
  30. Says the guy that features a ride with a sunvisor on his profile picture.[​IMG]
    No one is twistin' yer arm to read it....
    Change the channel if the topic bothers you so much.
