Just in time for Christmas. http://cgi.ebay.com/ebaymotors/NOS-KINMONT-DISC-BRAKES-32-FORD-FLATHEAD-HALIBRAND_W0QQcmdZViewItemQQcategoryZ34199QQihZ010QQitemZ200056663048QQrdZ1 Ya know, I've never seen them disassembled, they're quite odd. Rich
They don't look NOS to me. They look used. There was an NOS set on ebay a few months back. An Aussie hamber ended up with them.
FWIW, Kinmonts are the same functionally as Imperial discs from the early fifties. Possibly the parts interchange (cylinder kits, pad, etc.) Interesting seeing them apart as pics, the drawings in Motor can sometimes not give the whole impression. Cosmo
Those might look used because the hub is an original Ford part, and it was probably used before installation. I bet the iron parts were never painted and stored poorly. The cylinder kit is a simple one-half of a regular standard size kit, but none of the other parts are the same as any other manufacturer's (Chrysler). They work very similar to a clutch on a transmission. Picture the fiber-disc (clutch disc) spinning, but held by the outer edge instead of the inner. The pressure plate clamps onto it from both sides, the backing plate (flywheel) and the lever-fed ring (pressure plate).
Different from 49-55 Imperial discs (which, BTW, were four wheel discs), but I think those Kinmonts are missing something. I see the disc and pressure plate, but where is the flywheel?? I see nothing that looks like it would spin with the wheel for the disc to press against to stop the car. Or am I missing something?? Cosmo
Never seen a pair in person & this is the first time I've seen pics of them apart. Looks like the clutch disk outer splines fit into the aluminum scooped cover & rotate with the wheel/hub assy. They then get pressed between the backing plate (one of the pics shows the inside & it appears it has a surface) & the actuating assembly. But I'm guessing based solely on the pics...
Cosmo, the part that spins with the wheel is the ring with teeth, shown in the center of the bottom pics. To assemble the brakes, the backing plate is bolted to the spindle, the toothed ring is set up against the backing plate, the leveraged plate/ring is bolted on and sandwiches the toothed ring, then the hat/hub is slid over the spindle and engages the teeth on the fiber ring. The fiber ring kind of wiggles around until the hat is installed. There are a few small spring clips around the inside of the hat to keep it from wiggling once the hat is installed.
Ahhh...so I guessed right! Looks like a motorcycle clutch.... Also doesn't look like a lot of surface area - wonder how well they really work.
I haven't had mine hooked up, but Ken Gross told me the set on his roadster work OK. Not great, but OK. I've heard this from other sources too. If a guy is used to modern discs he'll probably be really disappointed. But if he's used to '40 Ford brakes it might be an improvement.
Morning this is an old post but I may have the Kinmonts your talking about in Aussie! Is there a Kinmnont go to guy that has the knowledge ? Cheers from Aussie Sent from my iPhone using H.A.M.B.
Thanks alchemy, is he on the H.A.M.B. & if so what is his "Name"? Cheers Wayne Sent from my iPhone using H.A.M.B.
Alan Johnson ~ http://www.johnsonshotrodshop.com/parts-brakes.php JHRS Kinmont Safety Stop Brakes There pricey but they sure look good & work great. HRP
The JHRS is irrelevant when it comes to real Kinmonts. Aside from maybe the adjuster nut on the back of the backing plate there is zero interchangeability. Those things are a disgrace
Wilson Welding " ... coming soon" .... for a while anyway. Hope he is in process of still. If one can reasonably fab' a new and improved ..... it'd be fun to see his version of. ==> http://www.wilsonweldingandmachine.com/
