For Sale: 1963 Dodge 330 Super Stock Clone I bought this car several years ago and have done minor changes. Car was feature in Car Craft back in 2003 before I owned it. Link to article on Hot Rod Magazines page to the article: http://www.hotrod.com/articles/ccrp-0308-1963-dodge-330/ Motor/Car Info: 1963 Dodge 330 Engine is a 440: 30 over 1970 HP block Steel crank LY Rods JE lightweight forged piston, 10.5 compression (runs on pump gas) Block drilled for 1/2-inch oil pick-up Milidon 7 qt oil pan Lightweight starter 906 ported and polished heads 2.14 intake valves (2.08 stock) and 1.81 exhaust valves (1.74 stock) Crane 1.5 roller rocker arms Cammonics roller cam: 292 duration with .540 lift Comp cams roller lifters MSD billet distributor Crane Hi 6 ignition Milidon true roller timing chain Mopar M-1 single plane intake 750 Edelbrock carb Doug’s 2" primary headers Jet Hot coated 3" aluminized exhaust 3-chamber flow master Big yoke drive shaft 727 trans with slip yoke tail shaft Pushbutton shifter Continental 10" 3200 stall converter 1965 8 3/4 rear end with sure grip 489 case with 430 gears Super Stock rear suspension Frame connectors Drive shaft loop 6 cylinder torsion bars American Racing TTO’s Trunk mounted battery Base coat clear coat black paint on super straight body Be-Cool aluminum radiator with duel electric fans High flow water pump and thermostat Front disc brakes with dual master cylinder Rust free California car. Front grill and headlight rings are chromed. Original taillights. All the trim is on it, and that stuff is very hard to find. Moon red metal flake steering wheel, I have the original wheel. Sun reproduction tachometer (They don’t make that anymore!) Seen in Aug 2003 Car Craft magazine Best of show 2003 Sacramento Mopar show Located in Flower Mound, Texas. $37,500.00
Bump I would consider trades of 1971-72 Road Runners that are numbers matching, 1939-40 Ford Coupes, or real steel Model A Roadsters (on deuce rails with cool mills…sorry, no Brookville’s) etc. of equivalent value or with a bit of money tossed in if not of equal value.
